      Nov 2004
      Pickering,Canada
      need help for driveshaft specs
      If anyone knows these specs please post them so I can get my driveshaft built.I need to know what yoke I need for my LT1 trans and a stock 10 bolt chevy rear end.If anyone knows these specs please post them so I can get my driveshaft done.
      Thanks in advance
      Steve
      Steve
      Jun 2009
      Decatur, AL
      I assume it's a 1st gen camaro? Also, it is an 8.2 or 8.5 ten bolt? The trans should use a 27 spline yoke, the same as a th350 or 4 speed muncie. You'll need to measure from the center of the u-joint of the pinion to the rear face of the transmission. Most places will tell you that you can have 3/4's of an inch to play with after it's all said and done in the total length.
      2001 Camaro Z28 (DD)
      LS3 525hp GM crate engine, built 4L60e
      1974 Camaro Z28 Type LT
      Solid roller 355 sbc with T-56
      The tape measure is your friend.
      Jun 2009
      Decatur, AL
      Yeah, I measured mine with a tape measure and it was hard to do it by myself under the car on the creeper trying to hold the tape measure to the rear flange and going to the pinion. Got my driveshaft back yesterday and it fit perfectly.
      Nov 2004
      Pickering,Canada
      thanks for the info guys!!!!!!!!
      Steve
