Results 1 to 11 of 11
Thread: Motor mount issues!
Okay, problem 1 solved. I got the bolts back in there, nut on top! I ended up using a 1/4 drive and a swivel socket I think the holes in the cross member where made just for that, it worked great.
I ran across another issue though. Now that I have the mounts bolted in, I can't get the through bolt that connects the mounts to the frame to fit. The holes won't line up for the life of me. They are close, but not close enough to get the bolt in on either side. It seems like the motor is sitting to high to bolt in, even after taking in completely off the jack. Any thing that might be causing this?
