Results 1 to 19 of 19
Thread: Power Steering Heat Issue???
08-16-2009 #1
- Oct 2006
- 59
Had the car out yesterday for a cruise around town and the outside temp was in the upper 80' to lower 90's. I drove around town then hopped on the freeway, then I got off on a back country road, about a 25 min. drive at this point. Once I got out on the counrty road I got on it and did some 6k rpm shifts. By the time I got to the end of that road ( aprox 3 miles ) I had little to no power steering. My house was only a mile or so from that point so I just drove the car home. When I pulled into the drive way my car was at 180 degrees, I grabed a thermometer and the power steering fluid was 160 degrees. After the car sat a couple hours I fired it up and went for a ride around the block, the steering was alittle tight at first but felt normal after a minute or two of driving. I have an AGR quick ratio box and one of there pumps as well with redline power steering fluid. My car did the same thing several years ago when I was running all stock parts, so thats why I went to an after market set-up. Is this more of a heat or rpm issue?
Sorry to run on but I wanted to give as much detail as I could.
08-16-2009 #2
I'm going to guess that it's an aeration issue. If the PS fluid was 160 then it really didn't get all that hot.
Jason Scheer
08-16-2009 #3
- Oct 2007
- ridgefield ct
- 876
was the reservoir filled and did it have any bubbles in it?
work in progress--for the next 10 years.
1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
