    Results 1 to 10 of 10
      May 2002
      Southeastern WI
      Using a Muncie with LS engine
      What bellhousing, clutch, etc. are needed? I assume a hydraulic throwout bearing. Will stock trans crossmember work?
      Jeff
      Jeff,
      Use a BBC bellhousing, factory style LS clutch and pilot bearing and the Muncie will bolt up. You can even use the factory mechanical TOB set up if you want. Or use an aftermarket bell designed the fit the BBC (with the 168 tooth flywheel).. you'll have a better chance at the 12 o'clock hole being drilled.
      Or... if you have a CNC shop nearby : I made an adapter plate from .800 aluminum plate that bolts to the LS factory bell and does the same thing. I'd be happy to share my dimensioned drawing with you. But I just made it end up like a BBC bell.
      On the x-member, I'm not so sure.
      jp
      ​John Parsons
      Maryland
      I ran a Muncie in my Mustang at the begining,until it broke 2nd gear.Used a truck bellhousing (cheap),and Ram hydraulic throw out bearing.Bolted right up.Ron
      Ron Schwarz
      Reading, PA
      Ron,
      Did you use the adaptor ring or the Autogear truck front bearing retainer to mate your passenger Muncie to the truck bellhousing?
      Jody Haag
      [email protected]
      Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
      610-413-8015
      Jody's Transmissions on Facebook
      Feb 2007
      USA, TN
      JP,
      The LS block will accept a standard Chevy bell? This is good to know.
      Jody's Trans,
      The Chevy truck bells used both the large and small registar depending on which transmission was installed.
      May 2002
      Southeastern WI
      If I remember correctly there is one bolt hole you won't use at about the one or two o'clock position if you are looking at the back of the engine.
      Jeff
      Maryland
      Quote Originally Posted by JodysTransmissions View Post
      Ron,
      Yes, you do have to run an indexing ring with the truck bell,truck transmissions have a bigger bearing retainer,and you do have to leave the pass side top bolt out,because the cylinder is too close to the bell housing bolt surface on an LS1. Ron
      Ron Schwarz
      Dec 2008
      Knoxville, TN
      Muncie 4-speed hydraulic kit & LS Bell, Flywheel
      We have all of the parts to get a Muncie behind an LS:
      LS 621 11inch SuperDuty Bell & ProTouring Clutch
      Lightweight Forged LS Flywheel
      Hydraulic Clutch for Muncie (all models, all cars, rods/trucks)
      The links will take you to the video ... you can find all of this on our web-site and our ebay store
      http://stores.shop.ebay.com/Keisler-Engineering
      Shafi Keisler
      May 2002
      Southeastern WI
      Ebay link is not working. Is there anywhere I can just look at the stuff and not watch all the videos?
      Jeff
      Dec 2008
      Knoxville, TN
      Quote Originally Posted by Van B View Post
      link fixed
