    Results 1 to 20 of 21
      Eastern Virginia
      Car audio for dummies?
      LOL Is there such a thing? When is an amp required, what size speakers to run with an amp, bass blockers, crossovers, bla bla bla?
      Scot
      86 Monte SS
      Eastern Virginia
      LOL there is such a thing:
      Scot
      86 Monte SS
      Oct 2002
      Houston,TX
      If you just list a few question i will be happy to answer then with basic true answers.
      James J.
      Eastern Virginia
      Well today I replaced the head unit & wala my crappy sounding speakers aren't so crappy.
      Scot
      86 Monte SS
      Macon, Ga.
      Quote Originally Posted by JamesJ View Post
      Can I just fly you here and you do my stereo? I think it would save time and be cheaper....lol
      Bill
      Trailers are for BOATS!
      Kansas City area
      How do you get bass in a convertible without putting sub woofers in the trunk?
      Quote Originally Posted by thedodgeboys View Post
      Use the biggest speakers possible inside the car, either in the doors, or kick panels. A good set of 6.5" drivers works OK, but here is something even better:
      http://www.woofersetc.com/p4753/ELAT...ent-System.htm
      Space becomes an issue when you start mounting big speakers in the front.
      Normal, IL
      Head unit has more rms watts that factory causing speakers to sound better. If you want more bass response from your door speakers, use sound dampner inside the door and then cover all the holes you can on the outside of the door (behind the door panel) to make the door act like a ported box. Really wakes up speakers no matter how craptastical they are.
      Eastern Virginia
      Other head unit was an old Pioneer unit that I have had for about 15 years or so. I'm gonna have to make some kind of box for the rear speakers to push the bass inside. Or get some woofers for the trunk. Can hardly hear the bass over the 3" duals & flowmasters.
      Scot
      86 Monte SS
      Quote Originally Posted by Samckitt View Post
      Getting good bass in a car is very hard. There is nothing wrong with using older equipment. There were some companies back in the early and mid 90s that were making killer stuff. Orion, ADS, Rockford Fosgate, all had great products. Not so much these days, but others have taken their place.
      In a nutshell....Aftermarket car stereos have "pre-outs" for expandability. Normally front & sub on entry level ones and front, rear and subwoofer on mid grade to high end ones. they look like female RCA plugs. They are ran to the amp via RCA wires to supply the signal/music. Each speaker is a channel. hence 2 channel, four channel, 5 channel, etc. amps. Then speaker wire is ran from the amp to the speakers. 75-100 watts per channel is more than enough for the cabin speakers (and would keep the amp costs down). Same principle for the sub-woofer: RCA's to amp, amp to subs. The amps are grounded and ran to the battery for power and a "remote" wire is ran to the headunit so they will turn on/off with the headunit.
      When are amps needed?: After market headunits only put out 15-35 watts per speaker/channel. If you want to run component speakers (when the woofer and tweeter are separate, but linked by a "crossover" to separate the highs and low frequencies for sound quality) or more powerful coaxial speakers (where the tweeter is mounted on the woofer) then you need a amp of appropriate wattage to push them. You also need and amp whenever you're installing subwoofers as well.
      If your just accustomed to a stock system, and don't need the "best", then you can have a killer system for very little coin. how much are you looking to spend? how complete do you want it? are you willing to modify the stock speaker locations (i.e. 4" to 5-1/4" or 6") or want them factory sized?
      Here are the specs on your car
      Front speakers
      Dash: 3-1/2
      Front Door: 4" Rear speakers Rear Deck: 4x10"
      My advise, 6" or 6-1/2" components and a amp for the front stage. let the headunit power the rear stage, and decide what subs, size, and how many will best suit your needs for what you listen to most.
      You can't be slick to a can of oil
      Oct 2008
      Don't do the 4x10 or 6x9s in the rear. Take the rear speakers out, and put a sub on that shelf in the trunk. And put speakers in the rear panel below the window You can fit 6.5'' round speakers there. Thats my plan once I get to it. I still haven't made up my mind about cutting the door panels for components. I want to see what ppl have done first.
      Steve C.
      Eastern Virginia
      Hmm. I'll take a look at that. I wonder if anyone makes that panel for putting a speaker behind it? Maybe win holes in it or fabric so it looks stock.
      Scot
      86 Monte SS
      Southern Indiana
      Aura Base Shakers
      Eastern Virginia
      Is it possible that the music sounds bad while motor running? Seems like it is that way, maybe some noise interference or something. Granted the exhaust is LOUD but seems like the sound is clearer while motor is off.
      Scot
      86 Monte SS
      Feb 2003
      SoCal
      You have the exhaust sound resonating in your vehicle, there could be the possibility of a slight whining noise but normally this occurs when you have added an amplifier (which in turns amplifies the whining) which is caused by a "ground loop" (central grounding is suggested), but the engine running normally has no effect on the music.
      In fact if you were running an amplifier it would sound somewhat cleaner due to the fact the vehicle was running and keeping the amplifier supplied with ample current/voltage to the power supply, which would mean the amplifier is putting out the advertised amount of watts
      Eastern Virginia
      I figured that is what it was from. I like the Flowmaster sound, but don't like the resonating. I guess I will have to change mufflers.
      Scot
      86 Monte SS
      Cornettsville, ky
      Quote Originally Posted by Bill Howell View Post
      i will drive there if you make it worth my wild
      Feb 2008
      why when im just 30minutes away lol if your still interested pm me
