    Results 1 to 12 of 12
      Dec 2007
      British Columbia, Canada
      Help me choose a clutch
      I plan on getting a hydraulic clutch soon. I have a TKO 600 and will be hooking it up to a L92 that will be around 550hp. I will be using the car on the street with hopefully a rare trip to the track to see how it does. What would be a good street clutch for my set up? I'm not particular to any brands so open to any opinions. If you happen to know the part number too, that would be great. Thanks in advance.
      Everett, WA
      Hey Mike!
      You're right on the threshold of selecting 2 different styles of clutch. If you are looking for more of a "street friendly" clutch that you can abuse, I've heard Monster Clutches is the shiznit. Take a look at their Level 2 or 2.5 clutches: http://www.monsterclutches.com/gm.html
      All the guys on the LSx forums are raving about this brand, so it's gotta be good.
      Wow, running a sale right now! Free shipping, $50 or $100 off depending on the flywheel you select.
      The few, the proud, the crazy... the LT1 owners.
      For the sake of clarity, clutches are not hydraulic. I am assuming what you mean is that you want to convert your setup to hydraulic actuation. This can be done regardless of the kind of clutch you choose. For excellent drivability I like my LS7 clutch. If you look at my build thread (link in sig) you can get more details on how to handle the hydraulics. A TKO behind an LSx is installed just like my Richmond 6 spd.
      Dec 2007
      Quote Originally Posted by 69LT1Nova View Post
      Hey Mike!
      Hey Andy...as usual trying to get me to spend more money Those are some pretty cool looking clutches. I was hoping to find one that I could get here for a change though. I figure I have to support the Canadian businesses at some point instead of always buying south of the border. Will keep that one in mind though.
      My bad. Thanks for clarifying that Andrew. I've actually looked at your build a few times, especially when I was debating about going to the L92.
      You can't go wrong with the LS7 clutch. If you want to spend more money, I've got some ideas for you.
      jp
      I've heard from a few guys that the LS7 clutch is a pretty good one. Frank was telling me that he loves the one he has. I think he said his was a McLeod. Will the LS7 clutch hold up to 550 hp okay?
      Quote Originally Posted by scherp69 View Post
      ....Will the LS7 clutch hold up to 550 hp okay?
      550hp at the crank? Sure. Keep in mind that the biggest enemy of an organic clutch, like the LS7, is heat. If you go to the track and slip the clutch at the line and continue to hot lap it, you will destroy it in short order. However if you are moving, and go WOT, in first or second gear, there will be no issues, since the tires are more likely to spin.
      Dec 2007
      That's okay, at this point I don't plan on racing the car anyways. I would like to get it to a track one day to see how it does, but it will be on the street 99% of the time. Is the clutch you are talking about: https://store.gmperformanceparts.com...umber=24248985
      Also, what would you recommend for a flywheel. An aluminum one or a steel one. Thanks for your help Andrew.
      Dec 2007
      Does anyone have any experience with the Keisler pro-touring clutches. I was looking at theirs and the price is pretty good. Here's a link: http://www.keislerauto.com/index.php...lutch-kit.html
      jp
      ​John Parsons
