Results 1 to 20 of 65
Thread: TKO 600 Vibration
New to Pro-Touring
- Sep 2007
- Baltimore, Maryland
- 75
TKO 600 Vibration
I have a 67 Camaro and I had a TKO 600 installed. I now have a vibration that starts at around 65mph and gets better around 80mph. I have had the tires balanced 3 times. In fact, the last time they were road force balanced. I had it put on the rack and the alignment specs were dead nuts on. The car was originally a PG car. The flywheel I used is a GMPP steel unit. 168 tooth. The original flex plate does not have weights on it. The vibration is ONLY between those speeds. I feel like it's in the driveline angles, but I have done all I can do with them. I tried shimming the tranny, but it makes a HORRIBLE grinding noise. I need to find someone near me that knows their s**t when it comes to pinion angles and such. If anyone can help I would really appreciate it. Thank you.
Charlie Knudsen
67 Camaro RS/SS 350
