    Results 41 to 60 of 303
      May 2009
      Pacific Thunder on the final stretch
      Hi again. I am going to try and update here as "Thunder" gets close to completion.
      The leaf springs have settled in as I've been driving it. I actually ordered and installed a slightly smaller tire (.9" diameter) which will lower the front 1/2" then I took out the 1" rubber coil spring spacer which should drop the front a further 3/4"
      I had to have the spacer in there to prevent the tires from touching the fender lips on turns.
      The car sat level, but looked lower on the back, so it should have a nice back to front rake when back together.
      I spent a lot of time modding the magnaflow exhaust kit and trans crossmember to tuck the pipes up nice and tight. This should allow for safe speed bump crossing etc.
      While this is going on the toploader is coming out and a TKO is going in (1.5 -2 weeks 'till I get it.) I have "adjusted" the transmission tunnel, and will be welding the last of it tonight, hopefully.
      Going low means I want to have the tranny up in the right position, not dragging on a funky angle, or at risk of hitting.
      At the same time all this is going on, the 428 is out of the car again. We are swapping camshafts. Did a long night last night with my engine builder, dissasembling and checking the engine.
      Looks like we have 3 bad valve seals and a failing intake gasket otherwise mechanically looks good.
      Hope to have the engine ready for a camshaft break in by the weekend.
      Also have a new aluminum rad (engine running very warm) which is going to go in with the rest of the mechanical parts.
      I'm glad in one way that I did not get the car in full paint, because of all the "fun" stuff that has had to go on to get this thing perfect mechaincally.
      Love driving it. Can't wait to get it back on the road!
