    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 43
      Nov 2004
      Forney, TX
      Ultimate Hot Rod Garage
      Will be starting on a new house soon and I've been thinking of all the things I can do with the garage since it'll be a clean sheet design. Back in the mid 90's Hot Rod (I believe, could have been Car Craft) did a story on the ultimate car guy garage - there was even an overhead layout showing cabinet/tool placement. Does anyone remember that story? I remember thinking it was very well thought out and detailed, but can't find the issue it was in for the life of me.
      I'm not talking about a garage-mahal, large-budget type garage, just a normal 2 car garage (3 car in my case - although the wife's car will undoubtedly take up one of the spaces) with your normal assortment of car guy tools - a couple of tool chests, an air compressor, shop vac, work bench, welder, floor jacks, jack stands...etc.
      I'm really looking for that issue with the story, but I'm willing to take any advice/input on how to set up the garage. Some of the things I already have in mind:
      1. 50a/220v outlet for welder/compressor
      2. Electrical outlets 36" high spaced every 4' along two walls - normal spacing on third wall.
      3. Plumbed for small sink - for hand washing, non-toxic parts washing.
      4. Multiple outlets in ceiling - for additional lighting, ext. cord on a reel, fan
      5. Insulated walls (builders in Texas don't normally insulate garage walls)
      6. Insulated garage doors.
      7. Absolutely level floor (you would be surprised how many garage floors have a slope to them)
      8. House will have gas, so I'm thinking of adding a drop in the ceiling for a future garage heater.
      That's about it so far. I want a lot of cabinets, but don't know what I'll do about them yet. Gotta be cheap - craigslist maybe?
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
      Mountain View, CA
      City code where I'm at required a slope on the garage floor. You might want to check your municipality.
      True T.
      My blog
      Feb 2003
      Houston, TX
      How can you call it "ultimate" without including a lift? Ask for 10' ceiling in one bay, along with 6" thick concrete. Now your 3-car garage becomes a 4-car, for only a few grand.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Kansas City area
      The slop sure help with water drainage if you park dirty cars in the garage and need to clean it out you will like it.(it snows in my area)
      I actually wash and wax my cars in the garage on hot and windy days.
      I had my garage extended 10’ deeper so I have workspace in front of the cars for all my stuff makes for a great work space.
      After I finish my convertible, I would like to tile the extra space.
      Feb 2006
      Wisconsin
      Quote Originally Posted by Nine Ball View Post
      X2 try to work a 4 post lift with bridge jacks into the budget or at least set one spot up for one.
      try criags list for cabnets tools ect..
      1968 Firebird. Owed and operated since 1981. 455 5 speed 4 link mini-tubed ect.....
      Dec 2007
      I personally would ad a drain in the floor of the garage for washing cars, wetsanding, rinsing out the garage. Also move the compressor outside and just run cheap pvc pipe into the garage with a few different places to plug in for air.
      Oct 2007
      Millsboro, DE
      x3 on the lift, if anything think where you may put it and put a 2-Pole 30amp circuit in for it. Also being in Texas how about a Mitsubishi Slim Jim A/C unit as well. Also do you have Neon signs and or clocks? Put receptacles high on the walls and have 1/2 operated by the switch so you can turn them on via a switch instead of having the strings hanging. Also a dedicated recpt for a fridge is nice too. Another thing i wish i had done is provision for washer and dryer for all the dirty car towels. Definitely a telephone jack, TV Jack and internet jack if you are not going to have a wireless router. Also stereo speakers in the ceiling and put the receiver in mechanical room or closet and pull the speaker wires back to there.
      John McCormick
      Nov 2004
      Forney, TX
      Quote Originally Posted by Damn True View Post
      I've already checked into that. I just moved from Denver where it was code to have a sloped garage floor, but here in Texas (where I live, at least) there is no such code. The sloped floor would drive me nuts every time I used a tool cart or anything else on wheels - I'd have to unlock the wheels to move it where I wanted it, then lock them back to keep it in place, then unlock them again to move it...on and on.
      Okay, scratch the use of the word "ultimate" (adequate, maybe?) The lift is a great idea but the cost of the lift, combined with the cost of the framing modifications to the garage and extra thick concrete it would require, puts it out of my budget. I could swing a few grand, but I bet the cost would actually be double or triple that, if not more. I understand that now is the time to do it, but, until my 3 girls are grown and out of the house I will be on a very strict budget with all of my projects - garage included.
      Quote Originally Posted by avewhtboy View Post
      ...Also move the compressor outside and just run cheap pvc pipe into the garage with a few different places to plug in for air.
      The original design had the water heater closet in the garage, but we will be using a Rennai tankless water heater that fits inside a wall, so I will use the empty water heater closet for the compressor. I plan on adding a few vents to the door of the closet to allow air flow and also adding extra sound insulation inside the closet to cut the noise. For plumbing, Eastwood has a quick-connect garage airline kit that I'll be using. For about $200 you get everything you need to have 8 drops through out the garage.
      Quote Originally Posted by bulldog19 View Post
      ...Also being in Texas how about a Mitsubishi Slim Jim A/C unit as well. Also do you have Neon signs and or clocks? Put receptacles high on the walls and have 1/2 operated by the switch so you can turn them on via a switch instead of having the strings hanging. Also a dedicated recpt for a fridge is nice too. Another thing i wish i had done is provision for washer and dryer for all the dirty car towels. Definitely a telephone jack, TV Jack and internet jack if you are not going to have a wireless router. Also stereo speakers in the ceiling and put the receiver in mechanical room or closet and pull the speaker wires back to there.
      Great ideas. Definitely had A/C in mind but never heard of the Slim Jim unit - I’ll check into it. Currently don’t have any neon, but want to start collecting them, so the outlets up high make good sense. The garage will definitely be wired for tv and sound. Internet will be wireless.
      Boyd
      OK
      Here is my list for my shop I am building. Concrete thickness varies for what area you live in by the way. I have seen some not even pour footings, which I think is nuts! 4" is just fine in most cases with good footings and ground. One good thing about a sloped floor is to insert a drain and you can do your wetsanding, wash the floors down ect. Cost of the pour would be more because it is a lot more handwork. www.garagejournal.com has some killer interior ideas.
      Gravel for Driveway
      Dozer for clearingConcrete Safe RoomConcrete FootingsConcrete 39.91 yardsConcrete (Porch, Driveway, and sidewalk) 9 yardsConcrete For Safe RoomFormsrebarSafe Room DoorSafe Room Door Lock SetWell System & Drilling, pumpInterior Water Lines pipePVC pipeSeptic TankSeptic PipeSeptic BlanketSeptic GravelMetal Building 40x80x14(2) Garage Doors (1 w/ garage opener) 11Hx12W(1) Walk-in DoorWalk-in door lock set w/ deadboltMetal Screws(1) Outdoor French DoorOutdoor French Door Lock set(4) WindowsBuilding InsulationShop LightsConduitConduit Fittings and mouting tapsElectrical BoxesElectrical Box CoversPlug-InsExterior Shop Lights Utility Sink (Near Apartment/Kitchen Wall)Utility Sink Faucet & HandlesMetal Paneling for Shop Walls (8" high lining the interior)(3) 220V OutletsOutdoor wiringInterior Electrical Wiring (12-2 & 14-2)Breaker BoxSwitches (12)Switch CoversElectrical CoversElectrical Plug-Ins (15)Electrical BoxesGFCI Plug-Ins (4)Kitchen LightBathroom Light/ventBathroom Mirror LightMaster Bedroom fan/lightMaster Bedroom closet lightLiving Room Fan/lightOffice LightLaundry Room LightDining Room light220V hook-up for laundry room and in HVAC ClosetCable wiringcable boxes (4)Smoke Detectors (6)Telephone JacksTelephone Jack CoversTelephone wiringwire nutscopper ground rodInstant Hotwater Heater (Electric)Complete HVAC system 1.5 ton A/C systemElectronic ThermostatDuct WorkVents (7) & 1 return Laundry Dryer Vent & HoseAlarm SystemCeiling Joist (2x8 on 16" centers)Interior Framing (2x4x8)Interior Insulation R-13 w/ 1040 total ft. sq. @ $80 per 163 ft.Ceiling/Wall Insulation (Foam)Office French DoorsOffice Closet Accordian doorsAccordian Door HandlesBathroom DoorLaundry Room DoorMaster Bedroom Entry DoorMaster Bedroom Closet DoorInterior Door Knobs w/ lockInterior Door Knobs w/ out locksApartment Entry Door w/ windowEntry Door Lock set w/ deadboltDoor Stoppers (4)Closet Rod (4)Closet Wood ShelvingCloset Rod mounts (4)Window BlindsSheetrock (4x8) (130 sheets total @ $7) Sheetrock all purpose mud (13) 5 gallon containers)Sheetrock tapeSheetrock ScrewsSheetrock Metal Edge Trim Tape $12/100 ft.Primer-Sealer for interior walls KilzPaint for Interior WallsSemi-Gloss white for trim and cabinetsInterior Baseboard and door TrimWindow Sill boardsLaminate Wood Flooring Laminate Flooring BarrierStove/OvenMicrowaveRefrigeratorGarbage DisposalDishwasherKitchen Sink TrapKitchen SinkKitchen Sink FaucetCountertopsKitchen CabinetsKitchen Cabinet Handlesice maker water line valveBathtub/showerBathroom Sink/CountertopToiletBathroom Sink FaucetTrap for bath sinkBathtub Showerhead Bathtub Faucet SetBathroom MirrorBathtub Drain set
      Crown Point, Indiana
      Here is the lift I have no post to worry about. Set you back about $4,000
      http://www.bendpak.com/products/auto...ifts/sp-7x.php
      Jan 2000
      Thousand Oaks California
      Quote Originally Posted by GRNOVA View Post
      Cool! Who makes that?
      Larry Callahan
      Founder / Administrator — Pro-Touring.com • G-Machines.com • HostMyJunk.com
      SEMA Hot Rod Industry Alliance Hall of Fame — Class of 2026
      Advertise on Pro-Touring.com • Shop Pro-Touring.com Merch
      Long Beach, CA
      That's a cool lift.
      I found this one, pretty cool. And you can break it down when not being used. Prices start at just under $2000.
      http://www.garagejournal.com/?p=325#more-325
      Matt Briggs
      1971 Camaro RS - Race car in progress
      Midwest
      Sink some radiant heat tubes in the floor... nice and warm!
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      Make provisions for the lift if you can. Hieght and concrete necessary in at least one bay. You can always buy the lift later. Heck even if you can't go a lot higher get the minimum concrete required for a smaller lift.
      More stuff:
      sink/shower (3x3 stand up)/ commode
      plenty of overhead lighting
      floor drains for washing down, etc
      tv/cable/phone
      extra phone cable for a security system
      Ramona, Ca. San Diego area
      Here in California, at least where I live, southern Cali you cant have a floor drain. At least one that is in your plans. Not to say that you cant build it and skim coat over it with concrete. I did that with a shower drain in one of my large closets that's attached to a bedroom for the future if I decide to make it another master bedroom.
      Just built my new house with 10' ceilings in my garage. Did the 20amp outlets every 6 feet with 220 amp for the compressor. Did the walls in 2X6 and both garage doors are insulated. It measures 34' wide by 27' deep with two 16'x8' and 12'x8' doors. I also added a sink in it for washing dirty hands. That's a must. Keeps the door handle to the house clean. LOL Lots of over head lights and over head outlets too. Right now its a catch all for all the junk and moving boxes. I cant wait to get rid of everything so I can apply floor epoxy.
      One thing to remember to do is before you drywall the ceiling is to throw plenty of sheets of plywood up there so you have walk and storage space. Put in one of them drop down ladders from depot that retract from the ceiling. Way cool to have for extra storage for the wifeys junk.
      oshawa ontario
      for a commercial style beam over 2 post lift you'll need a 12 ft cieling minimum.....took me over a year but I eventually found a used one on Kijiji (like Craigslist) for $1200, I called some places locally that sell lifts and they gave me a couple of names of guys who install lifts for them.....I had the lift professionally installed for $400 (highly reccomended).....I already had the electrical run and ready to go.....you need 6" of concrete to support a lift.....dig a little extra out around where you'll install the hoist, (you need 4" for a floor) you'll have way under $100 in extra concrete if any at all, get two or three quotes for the job.
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
      Edmonton, AB, Canada
      For cabinets, I went to a used office supply place and picked up some nice steel ones with folding doors and such. Most of them are fairly tall, or can be stacked easily. You could even custom paint em if you really wanted too...
      Colin
      1950 Pontiac 12.82@105
      1999 GTP
      oshawa ontario
      My nieghbour was tearing out his kitchen....I got his old oak cabinets for nothing.
      you can call some kitchen reno places for cabinets too, remember, these guys have to PAY to get rid of the old stuff, they are only too glad to give it to you, and they see tons of it.
      there, you just saved enough money for half a hoist.
      31 Scarab 2 x 454
      That's a great idea that a lot of people have thought of but when these guys go to a job to do a remodel, they don't take their time and remove the old cabinets carefully.
      They pretty much tear them out with hammer claws and pry bars.
      Maybe if you slip them $100 or something to save them?
      I worked in the construction field for a while to see them do this to them.
      67 Camaro convertible (Jinx)
