Thread: Power steering problem
Jeff, I would imagine if there was a binding issue, the steering would be very, very stiff with the engine off...but it says it doesn't matter if the engine is running or not.
I'd disconnect the return hose from the resevoir (plug the inlet), a put the hose in a bucket. Start the motor and check to see if fluid is flowing; and if it is, it should be a smooth flow with no bubbles. Did you thoroughly bleed the system?
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
