    Results 1 to 9 of 9
      Sep 2002
      San Jose, CA
      I'm not trying to sound condescending, but this is pretty far off. A 7500RPM 500+HP 350 is a pretty hi-strung. Before we get too far into it; you may want to consider another path
      That said
      The bottom end is not optimum, but not bad. I would tend more towards a Crower rotating assy for a 7500RPM Engine. Less weight is really critical at those RPM's.
      Not enough carb, nowhere near enough cam.
      You should be looking more at a 850CFM carb and a solid roller cam in the 260@050 range I would probably point you towards the Isky 201602
      A hyd roller really isn't good past 6200RPM or so
      If you ask me a timing belt really isn't a great investment. I've never seen a name brand double roller timing chain break when something else didn't go first
      The clutch probably isn't up to the task. You are going to want something in a Metallic/Kevlar blend
      Get an SFI rated Aluminum flywheel with this one.
      There's more to think about; but as you are probably thinking by now... this won't be a great street engine. We should probably talk a little more about goals and combo.
      Just call me Brett
