    Results 1 to 3 of 3
      Oct 2006
      Norway
      Pontiac 389 inital timing
      Hi!
      A friend of mine have a -66 GTO 3*2bbl carb setup. The engine is freshly rebuilt, and we had a little discussion regarding timing. He say the Pontiac engines have the timing adjusted with vacuum blocked and then connected so the engine is having 20-30deg ideling and 50-60 deg with full mechanical and vacuum advanse......
      Sounds like a lot of advance....
      Olav
      Cypress, TX
      I had my 462 Dyno last month and the timing was set at 32 degrees with a MSD 6al for 633hp/5600rpm.
      Southern Indiana
      If he drives it , set it about 12-14 initial see if it cranks ok, watch the idle rpm as the centrifugal advance may be trying to come in and need to have heavier springs as you dont want it coming in at idle, mixing the springs will help you tune it. Then hook your vacuum advance to manifold vacuum .
      You will need to adjust idle speed and mixture a couple of times till your done then set idle speed in gear, w/advance hooked up to manifold vacuum. If you dont have an adjustable advance timing lite, order a timing tape.
      Generally tune for dragstrip performance with initial and cetrifugal advance. Vacuum advance is for mileage and an adjustable advance can help if it like to rattle a small amount like at tip in from cruise.
