    Results 1 to 11 of 11
      Phoenix
      LS7 Clutch for LS2?
      I can buy a brand new LS7 clutch/ p-p off a crate motor getting an auto trans for $300. Looking for anyone's experience with this clutch. Motor upgrades will max out at heads and cam but is stock now and is in a 69 Camaro. Thanks, Erik
      Dunwoody, GA
      Will do you just fine unless you plan a lot of sticky tire high rpm launches. For street/fun driving, it'll be good.
      Trey
      ~ Jon Hammond
      Aug 2001
      Connecticut
      you may want to check to see if you need the flywheel too. I recall seeing the flywheel swap was needed to use the ls7 clutch on the ls1, not sure on the ls2....
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Phoenix
      Thanks for the input. I should have clarified I think. This engine/trans and stock GTO clutch has only 8K miles on it, am I gaining anything with the LS7 clutch or will the stock one in there do just fine for me. Thanks again!
      Linwood,NC
      I seem to remember that a stock clutch was good until about 400 Rear wheel HP and the LS7 was good until about 500. You will need the LS7 flywheel to use this clutch.
      I am using this clutch and flywheel in my LS2 69 camaro and have no complaints.
      Bobby
      Newbury Park, CA
      LS7 flywheel? Mine is an LS2 flywheel using a LS7 clutch package. This is the common swap for cars that are LS1 equiped.
      If the current engine is an LS2 I don't see why an LS7 flywheel would be needed.
      Aug 2003
      The LS7 is the best clutch option for 500HP to 550HP and less LS motors
      Linwood,NC
      Sorry, my setup is out of a GTO. I think the flywheels are different from the Vettes. In my case, with the information I got from LS1GTO.com, I had to change the flywheel.
      Phoenix
      http://kb.ls1gto.com/KB/article.aspx?id=10039
      It looks like a GTO LS2 flywheel, like I have, is different from a Corvette LS2 flywheel which is why I need it.
      If I get the whole deal for $300, good deal, yeah?
      Santa Barbara, Ca
      That's a great deal for $300. When I got my LS7 clutch and LS2 flywheel a few years ago, I think I paid $550 for it. I have had no problems with mine, and it dyno'd out at close to 550 rwhp. Driveability is excellent as well with no chatter and a very light pedal. I think it's a good investment for a H/C car. Buy it!
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      San Bernardino, CA
      i have an LS7 clutch/flywheel behind my LS1. no problems.
