Results 21 to 28 of 28
Thread: Orange Peel
05-01-2009 #21
For black I would sand and reclear, way easier to get a flat (less peel) finish then if you do not like you can sand some more and buff. This discussion about how much clear is worthless without knowing what clear brand, reduction rate used by your painter, and # of coats applied. 2 wet coats of high solids clear is ussually about 3.0-3.8 mils thick. you need at least 2-2.5 mils for the job to hold up in the sun over time. These #s are for PPG Global, if your painter used cheap stuff 2 wet coats may only be 2.0 mils which is not enough.
05-04-2009 #22
- Dec 2008
- Toronto, Canada
- 189
Here's some close up photos of the paint for reference. You can click on the links to see full size photos.
http://www.popfuel.com/images/junk/t...nt-large-1.jpg
http://www.popfuel.com/images/junk/t...nt-large-2.jpg
http://www.popfuel.com/images/junk/t...nt-large-3.jpg
http://www.popfuel.com/images/junk/t...nt-large-4.jpg
http://www.popfuel.com/images/junk/t...nt-large-5.jpg
Basically the whole car looks like this, although some of the top coats are smoother. It looks okay from about 5 feet away but up close it's all orange peel.Jeremy Wilson
1969 Ford Torino GT Fastback
05-04-2009 #23
- Dec 2007
- michigan
- 370
When I saw the first pics, I thought you must just be a very picky person, but after these new close up shots, I wouldn't be happy with that either. I cant believe the painter said it was good the way it is and to just leave it that way.
I agree with the other post here. sand it and put a few more coats of clear on it, then sand it and wheel it out.
Id check with the guy who did it and see what he would charge for two more coats of clear after a sand, if you guys are still on good terms anyway.2005 CBR 1000RR..."mostly stock".
1968 camaro... "in the works".
05-05-2009 #24How did you arrange the paint job? If it was time and materials, you may be out of luck - though the painter isn't doing his reputation any good by shoving this out the door. If it was a quote for a completed paint job, the painter is on the hook and should fix this at no cost.
I'd consider talking to your local magistrate.
05-05-2009 #25
05-06-2009 #26
- Dec 2008
- Toronto, Canada
- 189
I've decided that I can't live with the job this guy has done so I want to get a few more coats of clear put on it.
Anyone know a shop in the Toronto, Ontario area I can trust to do a decent job?Jeremy Wilson
05-06-2009 #27
- Dec 2007
- michigan
- 370
I dont know of anyone in that area, but I think I would get ahold of hte person that did the job and at the very least see what brand of paint he was using. I dont know if it will matter since its been awhile since it was painted and there shouldnt be any reactions, but you probably want to stick with the same brand just to be sure.
In all honesty, the orange peel pretty bad, well, really bad, but if there were enough coats of clear, it wouldnt be an issue. This guy should be willing to put a few more coats on at the very least at cost.
You may find it hard to get anyone to clear it other than the original guy. A lot of shops wont warranty something like that, and most of the time dont want to touch it just because they dont know whats under it. If they see the clear this way, they are gonna second guess this guys ability not only to spray, but to do a good prep job too.
good luck with this. I feel really bad for you in this situation. Ive seen better backyard jobs than this.2005 CBR 1000RR..."mostly stock".
05-07-2009 #28
