      USA
      TKO Parts. Where to get ??
      I'm trying to sort out the shifting ( into 3rd ) problem with my TKO 600.
      I've checked the bellhousing alignment / runout.
      I've got .0035" lateral runout , and .0025" difference in the parallel mounting surface of the trans. compared to the flywheel/engine.
      So , I think there is not a problem there.
      I also checked the clutch air gap / freeplay.
      I've got .050" air gap.
      Tremec ( courtesy of Jeff at Classic Chevy 5-speed ) sent me some new shifter lugs free of charge.
      I'm also gonna' install a new front input shaft seal , along with the big o-ring on the countershaft plug. ( It was seeping fluid anyhow )
      I've got the front seal , big o-ring , shifter lugs , and a new 3rd gear synchro blocker .
      What I need is:
      The 6 o-rings that go on the shift shafts .
      Where the heck can I get them ?
      I got the other parts from Southern Gear , here in Atlanta , but they say they can't get the o-rings ...
      Somebody help me out !!
      I gotta get this car back together for the Walter Mitty Historic Races next weekend at Road Atlanta..
      Jeff Tate
      U.S.A.
      Ortonville, Michigan
      You could try D&D performance. They carry a bunch of rebuild parts and might have the O-rings your looking for.
      www.ddperformance.com
      Billy Utley
      Also check out Liberty's Gear. They can even convert your TKO to dog-ring engagement. That will guarantee fast, accurate shifting!
      http://www.libertysgears.com/index.html
      NJ
      Rockland Standard Gear
      USA
      If the new parts ( and some practice on my part ) don't fix my shifting problem , I'm gonna' send it to them and get it fixed , once and for all !!
      Jeff Tate
      U.S.A.
      USA
      Scott Lindquist at Classic Motorsports Group sent me some of the o-rings.
      (They are always good to get support from.)
      Scott also gave me the phone # for Anaheim Gear ( 1-800-477-1103 ).
      I spoke to Eric.
      They do all the warranty work for that area..
      Jeff Tate
      U.S.A.
