    Page 8 of 8 FirstFirst ... 3 4 5 6 7 8
    Results 141 to 151 of 151
    1. #141
      Feb 2010
      how does the air ride feel ? does it feel to soft or just stiff enough because im thinkin bout running it? and how did you guys get the chrome bumpers black / paint or powdercoat?
    2. #142
      Jul 2008
      I did over 3000 miles through of the worse highways and streets in the U.S (yeah u NY, New Orleans etc) including 120mph runs on Taladaga and a day at the drag strip, air ride not only had what I needed but allowed me the adjustments for anything. air ride will be with me again in July for Bullrun 2010 NY to Vegas...Vegas baby.
    3. #143
      Aug 2003
      Quote Originally Posted by The WidowMaker View Post
      any issues running the 26.5" tall front tire? adequate clearance to go lower and wider? i was set on a 275/30/19 up front, but id love to fit the 275/35 thats the same height as your front tire.
      Tim
      We wanted more sidewall on the tires for better handling and ride, espeically at sustained high speeds seen on Bull Run Rally. Nothing quite like hitting a unsuspected change of grade at double the speed limit and having no tire around the rim!
      As for how low. We can ALMOST dirve it bagged out, but the tires do hit the inner wheelhouse just before totaly bottoming.
      I will bag it out and shot you a picture of how low it goes before it rubs
    4. #144
      Aug 2003
      Quote Originally Posted by jhowell34 View Post
      The air ride is the best combination of ride / comfort / handling / ride height adjustment anyone can ask for. As Ted (Team Chevelle / Bull Run Racer Owner) mentioned, we most likely would not have made it through much of the rally with a fixed height suspension unless we set it up much higher then a performance G machine should sit. They navigated protruding manhole covers in Manhatten that high centered some exotics, and pot holes that could swallow Smart Cars in New Orleans.
      We install and sell the Air Ride, if you have any questions, feel free to call and discuss.
    5. #145
      Dec 2007
      Carlsbad, Ca
      thanks Frank!!! the inner wheel houses will be custom on mine, so im really concerned about the fender lip under compression and with the wheels turned. i was going to run a 245/35/19, but decided to go 275. so i have both the 275/30 (close to the 245/35) and 275/35 to choose from. rears will be a 315/35/20 so i just dont want something too short up front. Thanks again!!!
      Tim
      Build Thread Link
    6. #146
      Aug 2003
      Here is a shot of it at Talladega at a very SAFE ride height. It can ride a little lower covering the lip of the wheel 1/2" or so
    7. #147
      Jul 2008
      We were 120 mph into the corners and she stuck like glue..
    8. #148
      Feb 2010
      sounds good now just need full spension setup for a 72 charger
    9. #149
      Jul 2008
      two weeks till bullrun 2010, Franks putting on the final touches.see you in NY,
    10. #150
      Jan 2007
      CT
      Where in NY do you depart from? I would love to watch the cars leave.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
    11. #151
      Jul 2008
      The standard hotel on the 10th around 9am.
