Results 1 to 13 of 13
Thread: DIY Engine Coatings
03-26-2009 #1
DIY Engine Coatings
I've read and re-read Steve Rupp's build-up of the 87 octane engine and seen a lot of good from the engine coatings he used. But all of them were applied by a professional shop. Main drawback I can see is expense.
I've seen a company that sells any type of the engine coating you apply yourself at home. Think these would be any good? I know the cost is a lot easier on my pocketbook if they are worth it.
Is this worthwhile in a daily-driven street engine? I'd like thought and ideas on this.
Doug Gulley
03-29-2009 #2Anybody? Ideas or opinions?
Doug Gulley
03-30-2009 #3You could always try one of them on a part and see how easy it is to apply correctly.
A lot of the time it is getting the product on properly that is the biggest issue and the reason you may want to go with a professional.
Of course, this may be easy enough, or you may be meticulous enough to get it all right.Jason Scheer
04-01-2009 #4Anybody else have anything to add? Good or bad experiences? If it's not any good I need to know so I don't kill my engine before I build it.
Anyone?Doug Gulley
04-08-2009 #5
- Jun 2007
- Farmingville, New York
- 70
I've used and had good luck with these: http://www.techlinecoatings.com/hi-performance/
04-15-2009 #6bump for me, too
04-15-2009 #7Fast01 that is the exact brand I had in mind. Care to elaborate on what you used, how you applied, and anything else to care to add?
Anybody else? I am getting ready to rebuild my 383 and can't afford to get things wrong, or to waste unneeded money either.
DougDoug Gulley
04-24-2009 #8
- Jun 2007
- 70
Sorry for not getting back to you sooner, but I'm not on here all that often. Anyway, I used this, http://www.techlinecoatingswebstore....1&product=1314 this, http://www.techlinecoatingswebstore....1&product=1312 and this http://www.techlinecoatingswebstore....1&product=1315
I followed their instructions exactly and am very happy with the results. Of course my wife wasn't happy about car parts baking in the oven! I coated the valve faces, combustion chamber and exhaust ports with the ceramic. I coated the valve springs, and valve stems with the liquid DFL and the valve guides with the powder DFL. I would've done the bearings and piston tops as well, but the short block was already assembled when I decided to give this stuff a try. Hope this helps!
04-25-2009 #9I have always wondered how long these types of coating would last on a street motor. Race motor I could understand since it is torn down and rebuilt all the time you could reapply the coatings, But on a street motor, I wonder how they wear?
04-25-2009 #10
- Aug 2004
- Belle Plaine, MN
- 1,221
