    Results 1 to 20 of 41
      Apr 2007
      Minneapolis, MN
      68 BYRD finally Driving (more pics)
      I finally got to drive the car today after along time working on it. My brother and dad did most of the work. It started out a pretty ok driver. Last year it was put in the shop in the fall to have some work done. We removed the engine and trans for the 3rd time('68 poncho 350 and 2sp auto) to fix some oil leaks. Stupid rope rear main. Thanks BOP for the updated Viton seal! An edelbrock performer and Holley carb were installed and the engine was dyno tuned @ MAS Performance in Ellsworth, WI. The radiator was replaced with an all aluminum unit from Summit. The fan shround was fabricated by my dad and an electric fan was added, also from Summit. The trans was replaced with a mild TH350. The suspension was upgraded with a Hotchkis TVS kit and Bilstein shocks up front. The brakes were upgraded from 4 wheel manual drums to 4 wheel power discs from Right Stuff. The 14" ralleys were ditched for 17" AR TorqThrust II's. F=17"x8", R= 17"x9.5". The tires are Nitto 555R. F=245/45 ZR17 R=275/40 ZR17. The rear end is the stock 8.2" BOP. The 2.79 open set up was swapped out for a 3.55 w/ Eaton Posi. We are very proud of this car because my dad, brother, and even mother at times did all of the work. Its now a totally different car to drive.
      Feb 2006
      Idaho Falls, Id
      Nice bird
      Traven
      nice!
      Aug 2003
      Awesome.
      You have a nice looking car, and you made some sweet upgrades just in time for spring.
      Arlington Heights, IL
      Thats a sharp looking car. You dont see a whole bunch of those. Very nice work!
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      Good work!
      Love to see the home and family built rides, especially the ones that look that nice!
      Mexico.Mo.
      Great looking Firebird! Its gotta be straight to wear black, and yours is. Very nice ride!
      Nov 2004
      Dallas Texas
      nice bird brother!
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Amsterdam,The Netherlands
      Country Flag: Netherlands
      Sweet!!!
      Cliff
      1968 Firebird
      East Coast Florida
      That's a nice looking Firebird you have there. ....and there is no snow in the background so that means you get to drive it now !!
      Project "Freebird"
      Dayton Ohio
      nice but where is the car's cheese head ;-)
      May 2006
      Wa State.
      -Ed Nelson
      1967 Firebird.......
      1970 Corvette. -Sold
      iceland
      Country Flag: Iceland
      Apr 2007
      Minneapolis, MN
      Here are some pics of when the work was being done. I know the engine is the wrong shade of Pontiac Blue for a '68. You gotta change it up, right.
      Oct 2005
      Greenville, IN
      DatS ReaL BaD! I love the wheel sizes ya went with. They fill the gap nicelY!
      Kevin
      Apr 2007
      Minneapolis, MN
      Thanks guys for the kind words.
      Code Red: The cheesehead is there, you just can't see it.
      Dayton Ohio
      hmmm those valve covers look familiar ;-)
      Jun 2008
      Cumming, GA
      68 birds are our favorite. Keep up the good work!
      Apr 2007
      Minneapolis, MN
      After driving the car for a little while it was back up on the jack stands to install the new exhaust. The rear sway bar from the Hotchkis TVS kit could not be installed due to the exhaust system. The exhaust was a custom compression bent 2.25" aluminized steel with Flowmaster 40 series mufflers. We opted for a header back kit from Pypes Performance. The kit is 2.5" mandrel bent stainless steel with a X-pipe. The quality of the system is very good. The system comes with clamps. We also installed the optional cut out lead pipes with electric cut outs. I know some of you guys are not fans for the electric cut-out. But they are fun. Anyways, instead of clamping the system we dry fit everything to get it nice and tight to the bottom of the car, then tacked and removed. The entire system was then fully welded from the mufflers forward. Also the lead pipes were modified slightly to get the valves just behind the front subframe rails. The kit went in fairly easily. The only thing that needed some "adjusting" was where the pipes go under the trans cross-member.
      Here is the original lead pipes w/o the cut-outs. The system fits up inside the drive shaft tunnel nicely.
      Here is the system tacked and clamped ready to weld together.
      Here is my dad playing with his new welder.
      Here is the "adjustment" to the pipes under the cross member.
      Here is the final assembly. Now we install it and fit and weld the tail pipes.
