Thread: Engine misfires
03-14-2009 #1
Engine misfires
Hi everyone. I have recently bought a Sunbeam tiger which is powerd by a 289ci Ford. When I got the car it was not running as it had no spark. It has a later model motorcraft electronic distridutor from a 302 in it. the wiring was a mess and the ign module that had been used was not working and seemed a missmatch. I had an auto electrician tidy up all the wiring and replaced the ign module with a bosch 9 222 067 021 module and that got the engine running and he is happy by bench testing the unit we have good constant spark now.
The problem is as you are driving it at part throttle you can feel it surging a little, if you put your foot into it, it accelerates fine. Go back to cruise and it surges again. It will slowly get worse and start poping and back firing and adventually stop. Now the strange part. If you restart it , it will run as well as it does again, but the engine is getting hot by this time. I had it out today and once it started to run very roughly I switched the ign off and coasted, then before I came to a stop I crash stared it in gear and away it went ( well, as well as it does ).
It has a brand new Holley street avenger carb on it and I have made a wooden carb spacer to eliminate vapour lock as these cars have small engine bays which are very full of engine.
Any ideas anyone.
Thanks Mal
