Results 1 to 14 of 14
Thread: T56 bellhousing
03-09-2005 #1
- Sep 2004
- Near Dayton, OH
- 547
T56 bellhousing
I'm in the process of gather parts for a T56 swap into my '87 Olds and have a question regarding the bellhousing.
I currently have a Lakewood Blowproof bellhousing that is setup for a Muncie, T-10, etc. Is it possible to have it drilled out to accept the T56's bolt pattern? If so, is there a company out there that can do this?
I contacted Lakewood about sending it to them to have it redrilled but they said they couldn't do it.
I also noticed that McLeod has a T56 with an adapter plate made to fit GM bellhousing patterns. Has anyone used this?
One last question, was the bolt pattern for the different transmissions used by GM the same? I know the Bellhousing-to-Engine bolt patterns are different but was curious whether or not the the trans-to-bellhousing bolt patterns were different between the different makes.
Thanks for the help!Andrew
1987 Olds Cutlass Supreme FE3X Clone
EFI455/T56/9" w/ 4.30 gears
__________________________________________________ __
