    Page 8 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
    Results 141 to 160 of 170
      Little Rock, Arkansas
      Daaahm. How thick are they?
      Dec 2008
      Lehigh Valley Pa
      They are 1/2 inch thick. I didn't want any sealing or warping issues due to heat.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      SF Bay Area
      Holy stink-a-mony! I have never seen flanges that thick! How hot does an Olds run?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by chunger View Post
      Well they will be for Turbo manifolds. I look at it this way. How many times have you heard "my headers leak cause the flange to thin" And these manifolds will be supporting the turbos. Not to mention they may need to be ground flat after welding so I have more material to work with in that circumstance. I don't want to have to do this twice because I bought something that wasn't strong enough.
      Rustburg, Virginia
      You could mill another 1/8" off to make sure they are true/flat ...thickest I've seen were 3/8" then you could use standard length exhaust bolts.
      Dec 2008
      Lehigh Valley Pa
      Hey I actually got something done today. Since I have owned the car the passenger side rear door has never worked. Well now it does. Kinda. It will open from the inside. But I need the plastic clip that goes over the rod and into the handle for the outside to work as well. I never saw a need to fix it realy because it never got used. The reason I fixed it? Well it's time to start on the door panels. I have seen other peoples work and want to give it a try. So I took off the front passenger side panel. Stripped it down to the door card. I was going to coat it with fiberglass resin while on the car figuring that would help it hold its shape. But even then it looked wavey. So I took it off laid it on the bench and used a cylinder head to hold it down and put a layer of fiberglass cloth and resin where it was flat. when it is fully cured I will do another section. Then once I get them all done like this I will decide on how I was it to look. I would like to redesign the arm rest and make it look better. I also took a look at doing my airdam splitter. Think I have it figured out for the most part. Just have to start making all the pieces to put it together. I am going to make two noses. One for street use where the splitter will be 5 inches off the ground. And one where it will be 2 inches off the gorund for track days. I amd going to make it all a quick change arrangement where the bumper, airdam, and splitter are all one piece and can be unbolted easily from the outside.
      Dec 2008
      Lehigh Valley Pa
      Look what I did today. This is just the start of the piece to fill the gap between the nose and radiator support, cover the top of the rad support, and cover and support the top of the radiator.
      I also did some more work to my door cards. I am going to have to decide how I want my door panels to look soon.
      Cool!
      Florida
      I like the idea of being able to swap out the bumper/spoiler combos. Excellent idea!
      Oct 2006
      McKinney, TX
      What did you use to get your base in under the fiberglass?
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by absintheisfun View Post
      Simple cardboard. It really works well. The resin soaks into it making it part of the piece. Allows you to use less fiberglass and is strong if you do both sides.
      Dec 2008
      Lehigh Valley Pa
      Ok I got a little more done to the radiator support cover. It is really coming along, Today I got the top part of the radiator done. There are a few spots I intentionally didn't do. I will get to them in finer detail when it's off the car. Once this sets I will remove it do some trimming and put a layer under it and then it should be plenty strong.
      Atlanta GA
      i like that closeout!
      and i got your Qs man!.. thanks!
      Cartersville, GA
      Cool thread Stickman! Love what you're doing with the wagon!
      Joe Hinds
      Preastoe, Denmark, Europe
      Really nice thread!
      Could you please help me find the place where you bought those seats? I cannot seem to find them on ebay, or they hide in the millions of hits I get when searching for bucket seats.
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by kadettcqp View Post
      Really nice thread!
      PM sent
      Erwin,TN
      Nice thread, Stickman!! Any more progress as of now?
      I am glad that I am not the only one to recognize the fact that later GM B-Bodies make for excellent Pro-Touring machines. Terry Stevens proved that with his '77 Caprice SS!
      Jun 2011
      Chicagoland Area
      Quote Originally Posted by The Stickman View Post
      PM sent
      Hi Stick,
      I just spent two hours reading this entire thread from beginning to end (including the YouTube vids) and all I can say is "wow" and you (& the wife) are truly dedicated to this build. I, along with many others, love the fact you are using the Olds wagon. Its a dare to be different project for sure.
      I'm in the same boat as the previous OP. Can you please share where you got those seats? I need to get some. I only saw they were called "MCR"
      Great build/thread and I'm following this one all the way through.
      Jul 2008
      ohio
      neil where did you get the seats i know u said bay but the seller? also how comfy are they?
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by craigs73 View Post
      Here are the seats. I think they are very comfy and have done a few hours at a time in them.
      http://cgi.ebay.com/ebaymotors/2-New...Q5fAccessories
