Results 41 to 60 of 170
06-03-2009 #41
- Dec 2008
- Lehigh Valley Pa
- 1,269
06-03-2009 #42cool progress. could you shave some of the holes on the bumpers?
06-04-2009 #43
- Dec 2008
- Lehigh Valley Pa
- 1,269
06-04-2009 #44
- Dec 2008
- Lehigh Valley Pa
- 1,269
Here is the rear suspension mods I have done. These are my Metco Billet Aluminum LCA's. I really like these arms. They are very nice quality pieces.
They allowed me to mount a sedan swaybar on may wagon until I can get a set of much bigger wagon bars.
Here are the arms mounted without the swaybar mounted.
Here it is with the swaybar mounted.
ANd here is a pic showing the twist in it.
1996 Federal Cadillac hearse
1988 Eureka Chevy hearse
06-04-2009 #45
06-05-2009 #46
- Dec 2008
- Lehigh Valley Pa
- 1,269
Ok I bought a new Edebrock High rise Performer intake part #7111. I bought it cause the old Performer is warped to hell and I need to fix the leak problem. ALthough I think it might be a problem with the head because the cast iron intake leaked at the EGR crossover too. But then again I didn't read the turkey try gasket directions either time i did it until after the last one that said to use gasket sealer around the ports. Never had to do this on any other car. So hopefully this will seal right and I can get all the performance outa my engine that I should. Here are so some pics comapring the 2 Performer intakes.
You can clearly see the new intake is about 2 inches taller than the old one.
Here is it mounted and with the carb on it.
Now it did represent a big problem. The base plate for the batwing aircleaner is flat so it sits up off the carb. Thankfully I had an old HUGE aircleaner that had a drop down base that is the same size. So I swapped one for the other(will need some trimming) and low and behold I can close my hood.
06-05-2009 #47Diggin' the new 'mani Stick! I love those aircleaners too. My favorite!
06-09-2009 #48
Starting The Transformation
- Feb 2005
- SF bay area, CA
- 135
About that shifter, why does it not ratchet from first?
06-09-2009 #49
- Dec 2008
- Lehigh Valley Pa
- 1,269
06-09-2009 #50
- Feb 2005
- SF bay area, CA
- 135
I'm looking at this picture:
It doesn't look like you can upshift out of first without lifting the lever. Am I seeing it wrong? I must be, since there are seven positions, (P R N IV III II I) but eight detents. I've never seen or used a ratchet shifter so pardon the ignorance.
06-09-2009 #51
- Dec 2008
- Lehigh Valley Pa
- 1,269
In order to opperate the ratchet part of the shifter you must "arm" the shifter by lifting up on the center section that looks like brass knuckles then letting go. then you can shift to the next gear when you are ready. This applies for every up or down shift. it sounds like more work but it works nice. Now if you want to use it as a normal shifter you simply hold the center section up until you get to the gear you want. If you go to my Youtube video's you can see how it works in part 3 of my installation video's. Brian Kilduff also has some YouTube video's of how it works.
06-10-2009 #52I like this project! Nice and unique but is looking sic!
Justin
1968 Camaro, 377, 4spd, P.T. project
2006 TBSS, Borla, Kooks, Volant, and tuned - Daily driver
06-10-2009 #53
