Results 1 to 20 of 28
Thread: Auto Craft LS1 Oil Pan???
11-28-2008 #1
- Aug 2007
- CT
- 799
There is a hole in the pan that doesnt have a hole in the block? Did you guys drill and tap the block?
Did you have any issue with the pan leaking if you didnt tap it??
11-28-2008 #2
- Jan 2005
- 36
yes you must drill & tap the block. It will most likely leak if you don't.
11-28-2008 #3
- Aug 2007
- CT
- 799
Do you know if you are able to drill and tap it while in the car??
Pretty sure it is leaking..
I just noticed the engine was leaking but didnt have time to jack it up and look..
What size bolt??
11-29-2008 #4
- Oct 2008
- Durham,NC
- 664
