      Dublin, CA
      Magnaflow Crossflow Install Question
      I am so thankful that Magnaflow is into saving trees, but some decent instructions would have been nice. Do the over the axle pipes go into the top or bottom pipes on the muffler?
      At the moment I have them in the bottom and nothing really lines up; pipes are hitting the frame and are not parallel to the floorboards. Also, the bracket on the over the axle pipe does not seem to line up to anything. Some finished install pictures would be great! Thanks.
      Brent
      1971 Camaro, LT1, 4L60E
      Aug 2005
      Patterson, NY
      First, look through the muffler. Is it two straight tubes, or is it blocked? If they are straight through (like Pypes does) then one goes in the bottom, and one in the top.
      Dublin, CA
      They are straight through, but both pipes are of equal length and radius, so they need to hook up at the same level. I am pretty sure that they connect to the bottom set on the muffler and the exhaust side to the tail pipes connect to the top set, but I would love to see a photo to get a better idea on the placement of the muffler.
      Brent
