    Results 1 to 20 of 20
    Thread: .82 or .64 TKO?
      Nor Cal
      .82 or .64 TKO?
      Hey guys. I have to send back my TKO 600 to get the shifter location changed, so I have the opportunity to switch to the road race version with the .82 overdrive/5th gear. Wondering if I should do it. Here is my setup and welcome comments and suggestions.
      68 Camaro
      Currie 9" rear with 3.70 gears
      TKO 600
      Procharged 406 small block = 650-700rwhp
      Air Bar 4 link
      275 front/335 rear tires
      Intended use: 95% street driving, maybe some road course or 1/4 mile for fun occasionally
      Thoughts?
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      My opinion? Go for .64. With that combination, you'll only be using 5th for freeway cruising
      You won't be disappointed with the .64 especially since its 95% street driven, Im curious about your clutch, with 700whp who's setup are using?
      Thanks Rich
      Nor Cal
      Quote Originally Posted by 67ragtp
      Thanks Rich
      I have the RST Street Twin from McLeod. Its rated to 800hp. Hopefully it works!
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Aug 2005
      Patterson, NY
      Just something to keep in mind, and it would already be an existing problem on your car anyway, but if you have a tall overdrive and short gears you can hit one of the critical speeds of a driveshaft, causing vibration at certain speeds.
      Again, since you aren't changing your rear gears you will not be changing the speed of the driveshaft at the speeds you already drive, but if you drive it faster due to the drop in rpm in top gear you could experience this problem.
      Nor Cal
      Quote Originally Posted by GetMore
      I guess I will only find out once I get in and try it, eh?
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Feb 2007
      USA, TN
      A couple of the drive shaft sites have a mathmatical formula for determining the problem RPM based on RPM, shaft diameter, shaft length, and type of metal. It can be solved by changing the drive shaft diameter or going to aluminum.
      Nor Cal
      Quote Originally Posted by TnBlkC230WZ
      The one that comes with my Keisler kit is steel I think. I wonder if I will need to upgrade to aluminum at my power level?
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Quote Originally Posted by Twentyover
      Agreed.
      Quote Originally Posted by Flash68
      68 Camaro
      TKO 600
      Air Bar 4 link
      Thoughts?
      Dave:
      The one thing no one has touched on here is, at what rpm does your motor start to build torque? With a 3.70 rear gear and figuring a 26" tall tire, a .64 5th gear will have you turning about 2200rpm's at 70mph. Is your motor making torque at that rpm? I know for some, that would be too low and actually cause lugging and chugging in 5th gear at that rpm. My general rule of thumb is to pick a gearing combination that allows you to cruise at approx. 200-300 rpm's ABOVE the point in your torque curve where it starts to come on. In other words, with my daily driver, I have a .67 5th gear and a 3.55 rear gear (26" tire). My motor starts to build good torque at 2000 rpm so with my gearing combination, it allows me to cruise in 5th gear at 2250-2300rpm at 70mph. This gives me performance when I need it (without having to downshift) and maximum gas mileage.
      Too often I have customers who buy a tranny based soley on the rear gear that they are running (or planning on running) and not consider the motor's torque curve and then call back all upset saying they should've gone .82 5th instead.....
      Just something to consider.
      Richard
      Tech Support
      Oct 2008
      i agree with above, i have tko600 .64 had 3.70 gears changed to 4.11 and should have gone to 4.56 w no problem my cars torque starts at 2500-3000 still cruise 70mph at 2300 rpms
      USA
      Quote Originally Posted by rj8806
      Dave:
      Richard
      Tech Support
      Ditto,
      Yep , what he said .
      Jeff Tate
      U.S.A.
      Nor Cal
      Dave:
      Richard
      Tech Support
      Hi Richard, thanks for chiming in here.
      Very good info and question. I actually do not know exactly when my motor starts making torque. I have a Dynapak wheel dyno reading from my motor in a similar previous setup, but I don't believe the low end numbers. See here:
      http://picasaweb.google.com/dwgordon...26657265265506
      But regarding your 70mph cruising speed, I honestly don't see myself cruising at less than 75 in this car so that raises the rpm a little bit. And there should be many blasts at well above 100 as well.
      And just for the record, I have no regard for gas mileage in this car. Would I like it to be nice and high? Sure. But I am making any decisions based on fuel efficiency. This car is intended to be loud, obnoxious (a little bit), fast, and handle well.
      I wish I had a better idea of the low end power of my motor to answer your question.
      I am leaning toward the .64 as of now.
      Also, Richard, I am moving the car this weekend and hopefully next week be removing the tranny and sending off to you. Will let you know!
      thanks
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Aug 2008
      Pgh, PA
      You've got to remember to consider torque and performance in ALL the gears. The problem is that you also need to figure what's happening in 1st gear too. The TKO600 has a very agressive 1st gear. Take a look at the final gear ratios of the TKO600 compared to the M20, 21, and 22 for example.
      My setup won't be on the road for several months - it's still in the build stages. However, I've put a Moser Trutrack 3:73 rear end with the TKO600 and will be running tires around 26.5". My motor is a Pontiac standard block, stroked with roller cam, heads, etc that will make around 600hp and tons of torque - early. The biggest question for me was the cam performance balanced against low rpm use of the .64 5th gear. If it works out the way I expect my 1st gear will be usable as will 5th. To be honest, I also considered the .82 ratio before making my decision.
      Nor Cal
      Quote Originally Posted by wmhjr
      Exactly. This is why most recommended I use a 3.50 or 3.70 gear for my combo. I chose to go 3.70.
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Aug 2008
      Pgh, PA
      Yeah, but just to be clear, in my case I had to balance having too LOW a first gear against too HIGH a 5th. With the 3.73 1st gear is probably going to be "barely" usable because it'll be so low. On the occassion that the car is at the strip (every once in a while) I'll probably be out of 1st instantly. But 5th will be usable - the pontiac motors are torque happy even with an aggressive cam. For 1st gear my car would have been happier with the 3.50/3.55 rear end but I was afraid 5th would be not that usable.
      Quote Originally Posted by wmhjr View Post
      Of the 2 TKO's available, the TKO has a taller 1st gear. Compared to a Muncie, yes it is shorter. Real world experience tells us that a 3.73 or 4.11 is fine with the TKO-600 when it comes to 1st gear.
      On a personal note, I had a TKO-500 in my '90 LX mustang and I was running 3.73's out back. 1st gear was over really quick. In fact, I never used 1st gear unless I was racing or just needed to buy a new set of tires. After I got used to it, I actually liked it but for most, it would drive them crazy. The TKO-600 has a 2.87 1st (the 500 has a 3.27 1st gear). If I'm not mistaken, the munice had a 2.52? so yes, the 600 is a little deeper.
      IMO, a TKO-600 and a 3.73 is the perfect combination. It gives you the quick performance off the line and very nice crusing rpm's in 5th.
      Richard
      Tech Support
      Aug 2008
      Pgh, PA
      Quote Originally Posted by rj8806 View Post
      Richard
      Tech Support
      Agreed, and that's why I went with this combo - EXCEPT you also need to consider the torque curve and values of the motor pushing it around. I'll be making very strong torque starting low and 1st will probably be a tire melting machine. With over 600lbs of tq that 1st gear is overkill. But my roller cam profile kept me from the 3.50/3.55 as I didn't want to make it so that 5th would be worthless under 75mph. Actually, I really wished there was something between the standard TKO600 and the RR version. Somewhere around a .72 or so would have been perfect for what I wanted to build.
      Of course, it's still all conjecture and math at the moment. Car work is still underway. Tranny has only been mocked up. Body work and paint won't be done until around end of March and then I'll have a couple months of final electrical, interior and trim work before it can be driven.
      Canada
      5th gear
      I was in the same boat as whmjr. So I went with the safe bet for my combo, the .82 in my tko600. 496ci with less hp than you have there. Reason being I figured I wanted to have the most useable spread of gears. I started off with 3.73 rear gears with a 315/35 tire. First gear was totallty useless to put any sort of power down. This combo makes decent tq down low so I went to 3.31's. I think it made all the difference. The car is just right from stop lights now and in 5th gear, it's still high enough in the rpm range that it's not chugging along without having to go 90mph. 1st gear is basically a burnout gear in any car in the 500hp+ range. I guess it also depends on how fast you want to go. I usually am only on the highway for 20-30 miles max. at a time between cities.
      Indiana
      Dave:
      Richard
      Tech Support
      X2 on this point!
      My Elky has a .64 o/d TKO, 3.70 rear, and 28" tires combined with a very torquey 454. Its road manners and drivability are fantastic!
      The 468 that's in my Chevelle is very peaky and doesn't like to run below 2200 rpm. When this engine was in the Elky with the .64/3.70/28" combo it would chug and buck and complain any time highway speeds dropped the rpm under 2200 rpm, which was quite often. The 468 is now backed by a .82 o/d, 3.25 gears, and 26" tires and at 70 mph it's running very happy at 2300 rpm.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
