Results 1 to 20 of 25
Thread: Fixing front suspension geometry
11-03-2008 #1
Okay, I have a 68 Camaro that I want to make into a long term, low-budget Pro-Touring car. I have heard all the nightmares about the bad geometry in the front end of the 1 Gen. Camaros. I want to create a car that is going to be a lot of fun on a windy mountain road and up for a very occassional track day or autocross event.
I was planning on the G-mod at first, it seemed cheap and effective, but I have been reading around here and it seems the problem isn't just the lack of camber. So now I am considering Speed-Tech upper control arms or the AFX spindles.
Which of these is the most cost effective way to get the gemotry issues under control? Do I need some combination of these things?
I will also need to upgrade (again, cost is a huge consideration) to disc brakes when I do these mods.
Any suggestions or personal experience with any of the above mentioned things, or a better solution?
J.R.
11-04-2008 #2I'm not a suspension expert. But I had a 1977 Camaro with sport front springs and everything else stock on the suspension. It then had a power adder (700hp+ estimated) intsalled which meant I couldn't drive fast unless in a sraight line and had to brake last week for corners.
I then intsalled Baer Track 13" front, 12" rear, SC&C UCA's, Global West LCA's, Strange adjustable shocks and Hotchkis 1 3/8" sway bar and now its drivable. In the UK its all corners especially in London.
The feel of the car encourages you to push on in corners. The brakes also give you the confidence to stay on the throttle longer.
Lastly the stock items were most probably worn out hence the massive performance gains. Just my experience limited to 1 test drive with the sway bar.
As for a better solution. I also drive a Porsche 996 C2. Its lowered and will out handle a F430. I think you'll agree its cheaper and much more fun to modify a musclecar. I can't even get the rearend loose on the 911 without driving like a mad man. To much refinement = no fun!!!!!
11-04-2008 #3
