    Results 1 to 20 of 21
      PA.
      To each his own. I`m sure you`ll be very happy with the front end you`ve chosen. For those that haven`t made up their minds though a few words. A C6 isn`t a 1st Gen Camaro. In fact it`s really not even close,they have totally different suspension requirements and actually run very mild geometry. Is it better than stock 1st gen? Hell yes. Is it ideal for a 1st Gen, nope, not even close. So unless you`re going to put your 1st gen on a diet,widen it about 6 inches,lower the CG several inches,set the motor back a foot or so and use a transaxle in the rear a C6 suspension is not going to be your best choice. How about if the C6 geometry is changed? Well then you`re starting all over again and all bets are off,it`s only C6 parts and you can`t base any of your expectations on C6 performance. There is no inherent performance advantage to using parts from a Corvette over using parts designed specifically for the Camaro. We know this,we`ve been selling a well designed C5 spindle based front suspension (our G-5) for years longer than any of these other outfits. It`s still a darn good system but the specifically designed variant of the AFX spindles still offers some advantages.
      At the end of the day it`s all about geometry and setup (spring and shock rates and alignment). If you can get better geometry (for YOUR car) and a better setup with the stock subframe and bolt on parts than you can with parts from a Ferrari the bolt on setup will still work better.
      I`m not saying that aftermarket subframes can`t be better than bolt ons, many of them are excellent. I`m just saying that folks shouldn`t automatically assume that they`re much better than a really well designed bolt on package.
      Note: By really well designed I don`t mean cool looking parts that don`t actually improve anything. I mean parts that address these cars geometry issues and fix them.
      IMO many folks would be much better off with a well modded front end (thinking AFX or Stage 2-Plus) and a good link conversion like the new Chassisworks G-Link in the rear than spending the same money on just a front subframe. It`s all about the total package. Mark SC&C
