    Page 2 of 2 FirstFirst 1 2
    Results 21 to 27 of 27
    1. #21
      Apr 2007
      Iceland
      And if you would want to do a chamfer you would type B, minus and your figure... B-0.500
      Some machines will also read CHF=0.500 and RND=0.500 for radius
      69 "GTO".. 18" custom ET wheels with 305 nittos/Dude built 464 Injun/round port heads/turbocharged-Single 88mm hybrid/316 stainless headers & exhaust/gunmetal gray/complete LS1 f-body brake swap/12 bolt/built 400 tranny/fiberglass street frontend etc.
    2. #22
      Oct 2007
      i was told when i was learning cnc lathe that the sparks are a good sign something is about to wrong.
    3. #23
      Oct 2005
      Greenville, IN
      Quote Originally Posted by orange69
      Sparks are CooL! Melted Balls of steel are my signal to stop?lolol
      Kevin
    4. #24
      Quote Originally Posted by Kiddi
      Chamfer on my lathe is (simple corner break 1 inch stock)
      G0 X .940 Z0
      G1 X1.0 z-.060 ( \ .060 chamfer no special code)
      make chamfer as long as you want G1 X1 z-4.00 for 4" taper of .060
    5. #25
      Aug 2008
      um guys...
      If this machine came from a factory... you better check the voltage and Phase of the power.. if this is a 3 Phase machine... you may not have this available in your area. I'd hate to see ya move in a big machine and then realize ya cant even turn it on!
      Any one can lurn to run a machine... but a vocational school is a big jump start.
    6. #26
      Jun 2005
      Quote Originally Posted by scottdidit
      I would like to think he looked into that already, but who knows. I had hoped to clean up the garage and get it in there, but he keeps insisting he wants to put it in the shed we have. But the shed has no power.
      I spent all Sat. last week, and most of Fri. this week fabricating some large shelving to store some things and give us more floor space so that hopefully the lathe will fit, but the more I talk to him the more I think he is only interested in storing it for me until I can afford my own place. But that will be a few years from now when I'm further along with my apprenticeship.
      Mathius
    7. #27
      Jun 2005
      So I finally got to see the lathe. It's a bit smaller than I thought it would be. It's manual. Definitely will need some cleaning up. It's probably going to be a good learning/starter unit, but nothing special.
      Actually a Craftsman lathe. I didn't even know they made them.
      This is as close a picture as I could find on the net. It's close enough without having actual pictures:
      Mathius
