    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
    Thread: sea foaming
    1. #21
      Apr 2003
      Central Valley, CA
      Quote Originally Posted by BRIAN
      The problem in doing any research is everybody just comments on how cool their car looked with all the smoke. I can think of a lot of things I can pour down my carb and create smoke. Heck, after a couple beers I can piss on the exhaust and make James Bond envious but not sure what good it would do???
      If it is that effective anybody do an oil change right after to verify the removal or deposits?? If not aren't you doing more harm then good recirculating all that loose contaminated oil?? The old ATF before an oil change worked somewhat but again it was followed with an oil change.
      I only use cleaners such as Techron before an oil change.
      After using GM Top Engine Cleaner I've looked down into the chambers & intake runners / backside of the intake valves using a flexible borescope. Very noticeable difference in buildup levels... dare I say an impressive difference.
      Besides, if it didn't work why would GM not only stock the stuff but also have it listed as a recommended procedure in various TSB's?
      The fact GM stocks their "Top Engine Cleaner" and recommends it is why I buy the T.E.C. rather than Seafoam.
      1969 Chevelle
    2. #22
      Tallahassee
      I followed instructions (well, I did pour it slowly down the primaries....), and I let it kill the motor. If fouled my plugs and I had to replace 'em before it would start.
      IMO, Get your motor up to operating temp and slowly pour water into the primaries. It gives a good internal steam clean and is free. No better results from Seafoam than plain water....
      Don't pour it too fast - you probably don't want to hydrolock your engine and bend a rod.
    3. #23
      Finksburg MD
      Would Seafoam help seal rings? I think my cylinders are glazed and oil is getting by the rings. I would rather not pull the engine to do a ring job.
      I've heard about the Bon Ami thing but am scared to pour that down my carb to help seal rings.
      I guess a leak down test is what I really need.
      69 Mach1
      Candyapple Red with White interior
      408C stroker
      587hp@6300 / 520ftq@5000
      Tremec TKO 600
      Moser 9" with 3.9 gears and Tru-Trac
      http://www.1969stang.com/gallery/COZ-69Mach1?page=1
