      Oct 2007
      Taxachusetts
      LS1 head porting
      Can 853's be made to accept 1.61 exhaust valves?
      Also, are the Z06 valves the same length, or can they be made to work on a "standard" LS1 type head?
      Farmingville, New York
      I don't believe the 853's will accept a 1.61" valve, the seats are not big enough. The LS6 valves from the 243 heads are longer (can't remember by how much) than the 853/241 valves to compensate for the smaller base circle cam used in the LS6 engine. GM decided to go that route instead of altering pushrod length.
      Felton, DE
      I wouldnt use the z06 sodium filled valves with an aftermarket camshaft anyway as their 'hollow' stems were not really designed for aftermarket valve springs and i have read several horror stories of them breaking.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
