    Results 81 to 97 of 97
    Thread: RtthIV
    1. #81
      Jan 2003
      Arizona
      Quote Originally Posted by Danny Thomas
      The autocross was awesome but my car failed to pass tech due to the fact my optima battery failed for the second time and the Auto Zone battery didn't fit in my DSE battery tray right and couldn't be secured enough for the autocross - Thanks Steevo. It was still fun watching all the others in the 100 degree weather. ......
      Can't wait till next year - you can bet that battery will be secure.
      Danny
      Aw crap, I'm sorry. But the word "projectile" comes to mind. You would've been way more pissed if your flawless quarter panel ended up with a giant reverse dent--or worse. Parking lot or not, the lateral forces are far greater than one might imagine.
      ________________
      Steve Chryssos
    2. #82
      Chicagoland
      Shoulda talked to me, I had our optima trays there at RTTH with me for the various different optima batteries also gave a couple away as door prizes.
      Jeff Schwartz 815-770-0751
      SchwartzPerformance
      Where classic style meets modern performance.
      455 Commanche Circle
      Harvard IL 60033
      SchwartzPerformance.com | Facebook | Twitter
    3. #83
      Jan 2003
      Arizona
      That's a good idea for next year since we seem to have one battery hold down fail each year. We don't like to see anyone get sidelined. Dual throttle return springs are another critical regulation. And I'd like to see a driveshaft safety loop mandate.
      ________________
      Steve Chryssos
    4. #84
      Jul 2001
      Detroit, Michigan
      Do they sell a stiffer return spring for the LS based throttle bodies?
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    5. #85
      tony, the ls-1 have a return on the tb, and the lokcar pedal has a small spring in it also
    6. #86
      Huh.
      My Holley TB has a built-in return spring, my Lokar throttle pedal has a return spring, and I've got two additional return springs connected to the cable. I should pass tech with 4 return springs!
      jp
      ​John Parsons
    7. #87
      Mountain View, CA
      Huh.
      jp
      ...and your calves are HUUUUUUGE
      True T.
      My blog
    8. #88
      Jan 2003
      Arizona
      I was referring to carbs for dual springs. Sorry.
      ________________
      Steve Chryssos
    9. #89
      Jun 2006
      NW burbs IL
      next year I'll need an electronic spring for the fly by wire system.
      Matt
    10. #90
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by jeff s
      Actually, his issue was a standard battery in an Optima holder. Unless your tray can also hold a standard battery, it wouldn't have worked. I went to Steevo for a second opinion as Steve's replacement battery had rags and towels stuffed in the compartment to keep it from banging around much. I still thought it was unsafe for competition.
      Allen Ortega
    11. #91
      Jan 2003
      Arizona
      We definitely saw an increase in the number of higher HP cars at RTH4 as well as an increase in competitive "spirit". Couple that with a potential second "road course" event for 2009 and rules will need to be more clearly defined for next year. We're running hot rods, not race cars so rules will not be overbearing--just much more clear and concise. We all do a pretty good job of building safe cars. And we do a good job of driving those cars within the limits. The dual throttle spring rule for carburetors is a good example of planning for when things go wrong.
      Look for an official set of rules and regulations on or about January 1st 2009. With the exception of a road course addition (where speeds are much higher), expect the format to remain largely unchanged.
      Bill has selected myself (a vendor--Twist Machine) and Andrew Borodin (an individual) as technical directors.
      ________________
      Steve Chryssos
    12. #92
      USA
      Sounds good Steev-O !
      Jeff Tate
      U.S.A.
    13. #93
      Belle Plaine, MN
      Aww man. After reading through all these posts, now I gotta talk the wife into this. Good thing we've got a 4-door wagon!
      I got her talked into the Gingerman deal, but this might have to be a multi-event program...are I call it a double-Bill?
      ~SP~
      Scott Parkhurst
    14. #94
      Grayson, GA
      Huh.
      jp
      Can you say scope creep?
    15. #95
      Grayson, GA
      Quote Originally Posted by Scott Parkhurst
      ~SP~
      It's in the top 5 car things you must do.....maybe top 3!
    16. #96
      Quote Originally Posted by Bow Tie 67
      Word....what's a throttle return spring?...LOL
    17. #97
      Belle Plaine, MN
      Quote Originally Posted by andrewb70
      Showoff....lol
      Scott Parkhurst
