Results 21 to 23 of 23
10-03-2008 #21
- Sep 2008
- Calgary, AB
- 71
I had the same issue years ago with a 6AL box. The car would not run. It was the lead for the tachometer, there was an adapter available from MSD for it.
10-05-2008 #22
- Oct 2008
- 1
back to basics
1 check your plugs
2 bad ground strap to engine and chassis
3 vapor lock
4 pinched or kinked fuel lines or collapsed
5 gas tank not vented properly
6 float sticking in carb
7 fuel pump weak or to much for carb[overfueled]
8 cracked distributor cap
9 vacuum sec opening or stuck open while normal driving
10 valve sticking in engine
all of these i have encountered at one time or another.
Hope it helps good luck.
10-28-2008 #23
