    Results 1 to 20 of 29
      North Carolina
      LSx Engine placement
      HELP! I want to order the stuff ASAP but I've searched and searched. As soom may already know I am installing an LQ4 into my 69 Camaro. What brand engine plates will keep everything in the same location so I dont have to modify my driveshaft?
      Also will the truck pan that my engine came with work in my car?
      Central Florida
      North Carolina
      I am using one of the modified viper tranny's. It bolts up to the Gen I engine, so when I bolt it up to the Gen III engine I was just curious if the mounts would keep it in the same position.
      Any thoughts on the oil pan?
      Jackson Ms
      i would do a header search and decide which ones you want to buy. then buy the mounts that match the headers. the mounts are the cheap part of this swap.
      with the hooker mounts, short steering arms, and a few other parts you may be able to get away with the stock oil pan.
      one PT member used his stock pan and i barely had to notch mine.
      Chris V
      SOLD
      Dunwoody, GA
      truck pans are very deep(3inches lower than your old SBC pan) I doubt it'll work. Swapping to an Fbody pan is a bolt in deal.
      Trey
      ~ Jon Hammond
      League City, TX
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
      North Carolina
      Thanks for those links, and yes there is a lot of information, but man is it all over the place...everyone has a different way of doing it. I guess thats what this is all about.
      So far nothing I read speaks of mantaining the tranny location. The shifter in my car is in a perfect position and I dont really want to move it.
      League City, TX
      Quote Originally Posted by 69importkilla
      Do some research on the Viper transmission. From what I've seen, it keeps the shifter in close to the same spot.
      John Brown
      Instagram @wilwaxu
      Facebook @wilwaxu
      North Carolina
      Yeah when the tranny is bolted to a Gen I engine thats not a problem, but I cant find what happens when you install "XXX" manufactures adaptor plates on the Gen III. Oh well looks like I'll just have to buy a common style and try it!
      Jackson Ms
      well the hooker mounts it way back so that is not what you want.
      to be honest i would worry more about other stuff then a shifter hole
      Chris V
      SOLD
      Nov 2007
      Pittsburgh,pa
      I'm not sure I agree with satistraction. I used hooker plates and when I bolted up my richmond 5 speed the shifter lined up with the old hole, and I was able to use my stock tranny crossmember. This did not happen with the s&p plates I had. Visually it looks as if the hooker plates put the ls motors further back but I believe it is because the passenger head sits so far back. I think the hooker plates put the bellhousing in its "stock" location. just my .02.
      Dunwoody, GA
      hooker plates are designed to set a Gen3/4 engine bell housing mounting pad in the same location as a SBC. That means the transmission will be in the same place. The problem you run into in general with these plates is that the heads on a Gen3/4 engine also sit further back on the block as compared to a SBC. So, the heads usually end up hitting some part of the firewall. If others have used the hookers in your same chassis, go for it. However, the hooker plates are quite possibly the ugliest most over priced plates. They look like they were made with a hacksaw, belt sander, and hand drill. They cost just a little less than others that look much nicer. I know functionality matters most. I just don't like seeing an ugly part that costs a nice amount of money
      Trey
      ~ Jon Hammond
      North Carolina
      I tell you guys I didnt realize it would be this crazy. But I guess if this is my biggest problem then oh well.
      Does anyboby have any dimensions for these plates?? I have access to a TRUMPF laser machine and can cut these plates out virtually instantly.
      It will suck to have to keep pulling everything in and out but atleast I can try the combination that works for me.
      Felton, DE
      I used ATS plates, Hooker ceramic long tubes, 327 frame stands, prothane SBC mounts, and a D&D LS1 viper t56, mountind location is perfect to me. I had to cut back about another inch or so to get it to fit from what i can remember. Nothing you would ever notice.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Aug 2005
      Hamilton, NJ
      Shawn, can you clarify on "cut back about another inch" - what did you cut?
      Scott from NJ.
      Vent Windows Forever! ...
      Nov 2007
      Pittsburgh,pa
      69importkilla pm sent
      Felton, DE
      I had to cut the hole that was origionally in my tunnel from the 3 speed about another inch or two further back to allow for the T56 shifter.
      north central Iowa
      http://www.lateral-g.net/forums/showthread.php4?t=16488
      if your dead set on keeping the trans where its at get some of these and bolt the eng. to the trans and weld the mounts in place.
      North Carolina
      I am not dead set on keeping the tranny in one spot. Since the machine is now programmed and the plates are cut, I am going to install everything and check the transmissions placement. If i need to move it, i'll just modify the program and cut a new set.
      For the guys who want the hooker plates cut out, I can do it in SS, steel, or aluminum. But I need the dimensions or the plate itself to reverse engineer it.
      Colorado
      I know its a little late but I had my t-56 bolted to my gen1 sb and then when I swapped in my LS2 I used the S&P style plates and it moved the engine way forward and I had to have my driveshaft lengthend.
      68 Camaro
      LS2 6speed
      Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
