    Page 2 of 2 FirstFirst 1 2
    Results 21 to 25 of 25
    1. #21
      Quote Originally Posted by Mike Holleman
      Andrew, I did some checking last night on the master you suggested.
      My master has the hose to the release bearing fixed and it is a GM style quick disconnect. Is the 96/97 the same or can it be changed to the quick disc.?
      Mike
      Mike,
      If you look closely, the fitting that hold the hose is held in place with a little roll pin. I believe if you take that roll pin out, the fitting will come loose. There is a little o-ring in there that makes the seal.
      Some clutch companies, SPEC for instance, use a different pressure plate and spring. So when the SPEC clutch is installed the position of the spring fingers is farther from the transmission than with a stock pressure plate. The TOB travel does not change, but now the spring fingers are further away, and the clutch doesn't fully release. So what SPEC does is they include a 1/8" shim that is placed between the TOB and front plate. This moves the TOB closer to the spring fingers and allows the TOB to release the clutch fully. But as I said before, I don't believe that this is your problem.
      Clear as mud? LOL
    2. #22
      Morehead City, NC
      Quote Originally Posted by andrewb70
      Mike,
      Clear as mud? LOL
      Yeah ,I'm following you. I may have found some of the extra pedal I need. When I built the pedal setup on the bench, I was getting full stroke. Now with it mounted something has changed just a little and my stop is not allowing about an 1/8" of travel. Gonna bend the stop abit and see what that does.
      Mike
    3. #23
      ....Now with it mounted something has changed just a little and my stop is not allowing about an 1/8" of travel. .....
      That would most certainly do it.
    4. #24
      Morehead City, NC
      Readjusted the stop. Gained about an inch of pedal before engagement. Why? When I made the mods to the pedal setup, it was on the bench and using measurements from the stock firewall. I spaced the ATS mounting bracket out with a couple of washers to adjust for the sheetmetal I would be adding to the firewall. I was off by approx. 1/8". Once installed that 1/8" shortened my stroke. It is still a lower release point than I'm used to, but I can live with it.
      Thanks for the help.
      Mike Holleman
    5. #25
      League City, TX
      Go tech info!
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
