    Results 1 to 14 of 14
      May 2008
      small nut big problem
      During the installation of a dual quad set up, a small 1/4" nut may have fallen into one of the four front cyclinders.
      The intake has been removed and I'm able to look around the valves and there appears to be nothing. Put a magnet down there and still nothing. I've searched all around the engine, engine bay and under the car. My conclusion is that the nut may have fallen into a combustion chamber and is probably sitting on top of a piston.
      Is there a special tool which can be used to find and retrieve the nut? Go through the spark plug hole?
      Scott
      68' Mustang
      03' SVT Cobra
      67' Mustang fastback Pro-Tour build
      a little pricey, but...
      Scott,
      there are video scopes now for occasions like yours:
      https://www.mechanicstoolsupply.com/...pes/index.html
      they are a little pricey but may be worth not having to tear your engine down or worse wrecking a valve, piston, crank or block...
      If you take the spark plugs out and turn the engine over by hand you may be able to put a magnet wand in the spark plug holes, or you may even be able to hear the nut in there.
      Good luck!
      Paul
      May 2008
      Thanks for the help, much appreciated !
      Scott
      68' Mustang
      03' SVT Cobra
      May 2002
      Northern California
      I bought a small magnet at a science show many years ago. Its 1/8" in diameter and about a 1/4" long. But it can pick up a 9" 5/8" snap on wrench. I epoxied that to a piece of thick copper wire just for problems you are having right now.
      Don't crank that motor till you find that nut. Hopefully its sitting on your tool box.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by MrQuick
      I bought a small magnet at a science show many years ago...
      Ummm... What were you doing at a science show? See, I KNEW you were a geek in hiding.
      Allen Ortega
      May 2008
      Thanks MrQuick ! Its ingenuity like that which helps to make this forum great.
      Scott
      68' Mustang
      03' SVT Cobra
      England
      Solder up a small car light bulb connect to the battery and put it down the spark plug hole you might see it.
      Oct 2007
      ridgefield ct
      do you know which cylinder? i'm assuming that there's only one with the intake valve open.
      thetoolwarehouse.net and i'm sure other places have a flexible LED flashlight with a magnet around the light. it's a little easier than going in blind or trying to put a magnet and a light in a small area.
      work in progress--for the next 10 years.
      1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
      May 2008
      Quote Originally Posted by megaladon6
      cylinder #6 is suspect
      Looked through thetoolwarehouse.net and found a few tools, the link below caught my eye.
      http://www.thetoolwarehouse.net/shop/SLI-PV618.html
      Thanks for the help (everyone), it gives this "butter-fingers" some hope..
      Scott
      68' Mustang
      03' SVT Cobra
      Nov 2001
      Sacramento Ca
      Check with your local big autoparts store. They may rent the scope you need.
      Tony Langlois
      1966 Corvair Monza
      snap on sells a really nice scope with a color screen and it lights up the inside of what you are looking at. see if your local dealer would demo it for you. Then its problem solved for free.
      May 2008
      Thanks guys, I'll check out the local autoparts store. Worse comes to worse, then I'll invest in a nice scope.
      Scott
      68' Mustang
      03' SVT Cobra
      May 2008
      Obtained a scope at a local auto parts store and found the nut. After looking at the front four cylinders and finding nothing it was time to use the scope on the top portion of the transmission. The nut ended up being located on top of the transmission (4spd toploader).
      The saga is over..
      Scott
      68' Mustang
      03' SVT Cobra
      May 2002
      Northern California
      damn, you know its always the last place you look. glad you found it.
