Results 1 to 14 of 14
Thread: small nut big problem
08-02-2008 #1
During the installation of a dual quad set up, a small 1/4" nut may have fallen into one of the four front cyclinders.
The intake has been removed and I'm able to look around the valves and there appears to be nothing. Put a magnet down there and still nothing. I've searched all around the engine, engine bay and under the car. My conclusion is that the nut may have fallen into a combustion chamber and is probably sitting on top of a piston.
Is there a special tool which can be used to find and retrieve the nut? Go through the spark plug hole?Scott
68' Mustang
03' SVT Cobra
67' Mustang fastback Pro-Tour build
08-02-2008 #2
- Dec 2004
- 203
a little pricey, but...
Scott,
there are video scopes now for occasions like yours:
https://www.mechanicstoolsupply.com/...pes/index.html
they are a little pricey but may be worth not having to tear your engine down or worse wrecking a valve, piston, crank or block...
If you take the spark plugs out and turn the engine over by hand you may be able to put a magnet wand in the spark plug holes, or you may even be able to hear the nut in there.
Good luck!
Paul
