    Results 1 to 20 of 36
      CT
      T56 Clutch alignment tool??
      Where can I get one of these??
      I assume you can use a standard smal block one??
      Felton, DE
      I got mine with the clutch kit. I dont think they are the same as an SBC kit although im not positive.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Dunwoody, GA
      AutoZone or the like may have one. It's a 26 spline tool. Or it may be 28 splines. I want to say 26.
      Trey
      ~ Jon Hammond
      Call Quarter Master and order a real alignment tool. Not some plastic donkey richard POS from the parts store.
      Feb 2007
      got one from auto zone worked great for me and at 3 bucks can go wrong.
      Henderson,NV
      You really don't need a great alignment tool like Andrew showed you unless you are installing a newer tranny. With the tight bellhousing tolerance and roller bearing it has to be perfect. ON the older trannies with bushings, it's not perfection.
      Todd
      Central CA USA
      Andrew, that's NICE!
      David
      Quote Originally Posted by Vegas69
      This is true, but that tool is not very expensive, and boy does it make it nice.
      Henderson,NV
      If I ever have to yank mine back apart, I'll be buying one.
      Todd
      La La Land, CA
      That is not an alignment tool, that is a spare input shaft!
      That thing is sweet.
      Oh yeah- T56 =26 splines.
      Tyler
      Walla Walla, WA
      Andrew: Nice find! I took one look at the picture and opened another window in my browser to order one.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Apr 2008
      for my swap I just used the parts store plastic piece and unless you've got too much money lying around it'll work fine
      Henderson,NV
      Wrong
      Todd
      Walla Walla, WA
      Quote Originally Posted by oldrednova
      Having pulled and reinstalled my T56 about eight times over the last four years and having had problems with the "parts store plastic piece" about 7 of those times, I'm very happy Andrew mentioned the Quartermaster alignment tool.
      Call me crazy, but when my own experience confirms what three posters with over 10,000 posts among them are saying, I'm going to go with my own experience and the guys with the 10,000 posts, rather than the person with 4 posts.
      As always, YMMV.
      Felton, DE
      I dunno ive never had any problems with the cheepo plastic tools, i guess i just got lucky.
      Encinitas, CA
      Cheepo plastic tools can work but they are not as accuarte as using a cut off input shaft as an alignment tool.
      This Quartermaster piece looks very nice - I called Quartermaster to find out more - it is not a cut off input shaft rather it is a custom made piece to tight tolerances.
      We currently use a an old input shaft for our installs but I will be buying one of these tools to check it out. We may end up recommending this tool as a great option to make the clutch install job and therefore the transmission installation job easier.
      Jeff Mortenson
      New York, NY
      I lined mine up by eye with the pressure plate loose, stabbed the transmission in there, wiggling it to get it to go in the pilot bushing. Then I carefully pulled it out and tightened up the PP.
      This only worked because I had the transmission suspended from an engine lift with the body off. I could make the transmission any angle I want and move it smoothly. I don't think this would have worked underneath a car with a tranny jack.
      Jul 2008
      Western Australia
      Quote Originally Posted by andrewb70
      Hi,
      can someome give me a link to this aligning tool in the pic please. As I have tried to GOOGLE Quarter Master an find it links to www.racingclutches.com , but when i try that link it does not find anything.
      I need to buy one of these tools to help me set up a twin disc clutch for a GM Holden T56 gearbox.
      I know a old input shaft is the go but finding one of those over here is as rare as rocking horse dodo.
      Thanks for any help.
      Cheers
      Deek
      Walla Walla, WA
      CT
      I got a $2.59 one from the parts store and it worked just fine..
      Thanks guys
