    Results 1 to 11 of 11
      Denton, Texas
      Street Legal Indy Car
      ~Chris
      1973 Mustang SportsRoof
      Miami
      saw it at SEMA a few years back...
      Beaufort , NC
      Seen a couple of those on Ebay,not to impressed with the small Mopar V-6 and the auto trans. Make it one seat shorter and put a Hyabusa in it and you would be closer.
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
      Boston, MA
      I think it's ugly but to each their own...
      ~Ryan
      Feb 2001
      Portland, OR
      I'd Rather have this:
      a power-to-weight ratio double the Bugatti Veyron’s, and so much downforce you will be able to drive it upside down in a tunnel at 150mph
      Caparo T1 vehicle specification
      Overall description
      Advanced technology composites for ultra lightweight construction
      575bhp V8 engine / 550kg kerb weight
      1,045bhp-per-tonne power-to-weight ratio for ultra high performance
      Fully tuneable aerodynamics
      2-seater
      Rear mid-engine layout
      Built for discerning customers but also technology flagship for Caparo Vehicle Technologies - demonstrating principles of lightweight vehicle design which can also be applied to everyday cars
      Aerodynamics
      Front cockpit road aero screen, other options available for track use
      Ground effect diffuser
      Adjustable front twin element wing
      Adjustable rear single element wing
      Adjustable fowler flaps
      Low drag body design
      Range of wing options for road and track
      Steering
      Magnesium cased lightweight high ratio steering rack
      Bespoke removable steering wheel
      Capacities
      Dry sump tank 8 litres
      Fuel tank 70 litres
      Body
      Carbon fibre multi part body with tuneable aerodynamics
      Designed in sections for easy repair
      Carbon/glass and Nomex panel construction
      Chassis
      2-seater carbon/aluminium honeycomb monocoque
      Separate front composite crash structure
      Rear tubular aerospace grade steel space-frame
      Suspension
      Streamline double wishbone front and rear
      Tuneable front and rear anti-roll bar
      Five-way adjustable race dampers
      Safety
      Central safety cell with high strength steel roll hoop
      Composite front crash structure
      Head protection system
      6-point harness for driver and passenger compatible with HANS (head and neck restraint system) device
      Fire system
      Electronics
      Fully tuneable engine ECU
      Bespoke wiring aerospace grade loom
      Multi-function race dash including data logging
      Speed sensors for traction and launch control
      Fly-by-wire throttle for optimum tuning
      Gearbox
      Bespoke magnesium pneumatic paddle-shift gear change
      Paddle-shift gear change control
      Limited slip differential
      Equal length hollow tripode driveshafts
      Various gear and final drive ratios available
      Brakes
      355mm diameter steel race discs front and rear
      Fully floating discs
      Front 6 pot billet machined race callipers
      Rear 4 pot billet machined race callipers
      Fully adjustable brake bias pedal box
      Pad compound options available
      Equipment
      Road legal SVA approved road version and full track versions available
      Road and track parts fully interchangeable
      Wet weather canopy/bib screen or race screen
      Further bespoke options to individual customer requirements
      Weight
      550kg (dry weight)
      Caparo V8 engine specification:
      Bespoke 3.5 litre normally-aspirated fuel-injected V8
      575bhp (425kW) at 10,500rpm
      420Nm (310lbft) at 9,000rpm
      Original concept tested at up to 700bhp (515kW) on methanol
      Limited to 10,500rpm for reliability but designed for maximum 12,000rpm
      90 degree V8, 4 valves per cylinder, 4 overhead camshafts
      93mm bore / 64.3mm stroke
      Finger follower valve train system
      Lightweight titanium valves
      Aluminium head
      Aluminium block
      Steel billet ‘flat plane’ crankshaft
      Internal piston cooling system
      Aluminium / Nikasil liners
      Gas filled ring cylinder head sealing system
      Dry sump with one-piece sump / ladder frame for increased stiffness
      8 butterfly throttle system
      Electronic sequential fuel injection system with twin-spray fuel injectors
      Engine concept is essentially to Indy racecar specification but with revs dropped to 10,500rpm for extended reliability in Caparo T1
      Pectel SQ6 engine control unit (ECU)
      Engine is fully stressed but installed in T1 to take torsion loads only
      Longitudinal, lateral and vertical loads taken up by tension and compression links to the rear of the chassis
      Engine runs on 98RON pump fuel at a fuel pressure of 5bar
      Fuel system is a return top tank system to eliminate fuel vapourisation
      Engine bottom end modified from race engine specification to increase main bearing tolerances and help cold start of the engine
      A bespoke carbon air-box and filter tray has been designed and installed to suit the Caparo T1
      Air filter is a mesh and washable filter system
      All up engine weight with ancillaries is circa 116kg
      (Source: Caparo)
      The Caparo T1
      Daniel Kuehn
      '71 C-Prepared Chevelle
      Beaufort , NC
      Cone...What is that?????
      Feb 2001
      Portland, OR
      Quote Originally Posted by Restomod
      Added more info and a more stable picture...........
      Daniel Kuehn
      Fife, WA
      The CaparoT1 is pretty cool- One was at SEMA two years ago. Around $600,000 and very tempermental. Lots of fires - Top Gear tested it and they weren't real impressed. Like an F1 car if it isn't driven at its limit it doesn't work very well.
      Beaufort , NC
      I like it but for that $ I would just buy a Radical (it to should be able to drive upside down) V-8 (Hyabusa based) and save $500K.
      Feb 2001
      Portland, OR
      Quote Originally Posted by CraigMorrison
      The CaparoT1 is pretty cool- One was at SEMA two years ago. Around $600,000 and very temperamental. Lots of fires - Top Gear tested it and they weren't real impressed. Like an F1 car if it isn't driven at its limit it doesn't work very well.
      I take everything Jeremy Clarkson says with a grain of salt though. Remember he thought the Z06 was a rattle trap. You cant argue with the Stigs lap time. Some 15 seconds quicker than any other non-race car........regardless of Clarkson's opinion it is street legal in Europe. I think they are getting past their teething problems though. If I was in that income bracket it would be part of the stable.
      Daniel Kuehn
      Daniel,
      Where have you been? haven't seen you around here in ages!!!
