    Results 1 to 20 of 21
    Thread: Porsche Brakes
      Jan 2002
      Italy
      Porsche Brakes
      Hi All,
      Thought I'd post some pics of what a friend and I did during the christmas holidays, the brackets that hold the calipers to the spindles are not made yet, but you get the idea.
      Specs are:
      360x32mm Audi RS-4 rotors with homemade steel hubs and Porsche Cayenne six piston Brembo calipers all mated to Corvette C-4 spindles.
      I think it should be nice when powdecoated and painted.
      Let me know what you think?
      Ciao
      André
      Oakland CA
      Man is that thing gonna stop!!! Wish i had some engineering backround and $$$ so i could create somthing that awsome. Keep up the good work!
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Jun 2004
      Tacompton
      cool
      Tigergutt you have a pm. Check your inbox.
      May 2002
      Northern California
      Hey Andre', any reason why you didn't use the 18" rotors???? ;) looks good. I may just use the yellows and run an Audi bracket. looks great
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jan 2002
      Italy
      I do not have an engineering background, I'm just a gearhead.
      My friend is a mechanical engineer and have access to a machine shop.
      we have about 20hours into this setup as is and there is probably ten more involved before the brackets are done, the bolts are drilled for safety wire its painted etc.
      at shop rates that means 30 x $65 $1950 (in Norway they are more than double of that) plus materials
      I actually thought about 380mm's (no kidding) but I found out that I had to contain myself and my wallet a bit.
      If I were to redo it, I'd get some rotors that fit and buy the calipers then fabricate up the brackets.
      Vince, the yellows ?? are you talking about yellow Porsche calipers? the ones from the 996, they are four pistons and Nice!
      In my sick head I am alreeady thinking about using the front ones at the rear :o)
      Ciao
      André
      May 2002
      Northern California
      yeah,996's they aren't too bad $$. 18"/380mm sorry I forgot your over there. I was eye ballin them Cahyennes but didn't want to run 20" rims!!! I didn't think about the smaller rotors. I hope your running skid plates on your front bumpers! heha bueno
      Nov 2002
      Finland
      Vince, 380mm is more like 15"... 18" would be close to 460mm
      Chris
      Jan 2002
      Italy
      yeah,
      Christer is right.
      to obtain mm from inches multiply by 25,4
      to obtain centimeters multiply by 2,54.
      to obtain inches from mm divide by 25,4
      to obtain inches from cm divide by 2,54
      so its like this
      360mm / 25,4 = 14,17"
      380mm/ 25,4 = 14,96"
      18 x 25,4 = 457,2mm
      I thought about running small wheels underneath ahahaha
      Ciao
      André
      Albuquerque, New Mexico
      What do I think?!
      I just had to send the link to my buddy, who isn't a PT guy, just because I thought your choices were so impressive, and also generally cool.
      -Matt
      Feb 2001
      Portland, OR
      That's pretty slick. I'm interested in seeing the final outcome. Those calipers are massive. What are going to use for a master cylinder?
      Daniel Kuehn
      '71 C-Prepared Chevelle
      Jan 2002
      Italy
      Glad you like it!
      I thought about using the C-4 master cylinder but I'd need someone to help me calculate if that works.
      Otherwise I could go with a Porsche unit.
      I'll post more pics as soon as the brackets are done.
      Ciao
      André
      May 2002
      Northern California
      sorry christer, i thought i was being sarcastic, it was a stupid comment. I will start using j/k for now on. chow j/k
      Jan 2002
      Italy
      Vince ?? I didnt get that with sarcastic etc.
      I'm sure we all understood that you was just kidding with 18" wheels
      btw I just re-read my post and I meant small wheels under the bumpers instead of skid plates, I saw those on C-5 vettes, look funny.
      Ciao
      André
      Nov 2002
      Finland
      yeah I did get that in your first post but then when you put 18"/380mm in your second post I thought your math just sucked
      and I'm just kidding
      Chris
      May 2002
      Northern California
      you tellin me, I can barely count to 5 with my shoes off, much less convert inches to mm's...wait, are you sure, I came up with 461,2...or is that 4,612...you guys suck ,he he haaa ha.
      Mar 2002
      Redwood City, CA
      Vince, it's time for your medication and to put your comfy little white jacket back on. You'll have more playtime tomorrow.
      Allen Ortega
      Aug 2002
      Sweden
      Country Flag: Sweden
      Looking good looking good...
      May I ask how much the rotors and calipers weight?
      Keep it up!
      Jan 2002
      Italy
      I dont know how much but they are for sure heavy with all that Iron.
      I hope and think that they are lighter than the standard rotors with the Delco Moraine iron calipers and the steel spindles though.
      I'll put it on a weight as soon as it all come down from Norway.
      Ciao
      André
      Aug 2002
      Sweden
      Hey... Norway, that's close to me!!!
      Ripper, Sweden
      Jan 2002
      Italy
      Actually the guys are even closer right now, they are at the Ĺby swap meet.
      Hey man lets do like this, you go to Oslo end weight them and then you let us all know hahahaha
      André
