    Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 142
    1. #21
      May 2008
      Denmark
      Country Flag: Denmark
      Making room up front. It's a 8.2" deck 363 DART stroker but still nice with more room for the headers to go forward and meet the turbo. The donor car was actually very nice as can be seen, not much to clean up and the driveline (420W w/Toploader) has been transplanted into another coupe of mine.
      Other rides: 1969 Mustang GT1
    2. #22
      May 2008
      Denmark
      Engine is starting to come together. DART block with 4.125 bore, 8.2" deck. Diamond pistons, Eagle forged stroker kit, CamMotion custom solid roller turbo cam with low duration, good lift, 114° lobe separation. Vic Jr heads are getting a mild port job + matching.
    3. #23
      Normal, IL
      Renderings look great! Looking forward to more progress pics!
    4. #24
      Midwest
      Man that is an awesome looking car. I love the colors, the 2-tone break, the wheel choice... it's a 10. Great renderings, too. I'm starting to sound like Paula Abdul, but I really like the car!
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
    5. #25
      I will be watching this project I like the rendering. I say keep the door handels. I also like how the rear spoiler is mounted kind of a mix of old look and new tech.
      71 Torino HT
      351w
      Aod Trans
      Project Updates https://www.pro-touring.com/forum/sh...ad.php?t=37854
    6. #26
      Chicago
      Not sure how i missed this thread - great looking project
      subscribed
      marty-mj
    7. #27
      May 2008
      Denmark
      Thanks!
      Door handles are staying BTW as well as drip rails. Difficult to keep the balance between old and modern, but door poppers are too much I decided.
    8. #28
      Nor Cal
      Bad ass renderings and project!
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
    9. #29
      May 2008
      Denmark
      Some more progress. Pumpkin done with gears and Truetrac, rear end is up, K-member test fitted up front, trunk lock and antenna hole deleted.
      Engine and T56 are next!
    10. #30
      Dunwoody, GA
      awesomeness
      Trey
      ~ Jon Hammond
    11. #31
      May 2008
      Denmark
      Progress pics! This time the 363 long block and T-56 tranny being test fitted. Had a fault in the World block casting and one ear broke off with very low torque on the tranny-to-block bolt! Welded back in place, NP warranty by Total Performance.
      Also have the subframe connectors welded into the floors. Once connected to the 8 point roll bar this is going to be VERY stiff!
    12. #32
      Arkel,the Netherlands
      this is gonna be 1 cool car once its finished, love the ideas that are going into this thing..
      that AJE K-Member , is that specially for a 69-70 Mustang, or is it for a foxbody or SN-95 or something like that?
      once i had a brainwave thinking about the same thing..
      just throw a K-member from a SN_95 under there with the struts..
    13. #33
      Nov 2004
      The rendering looks great. Very cool project.
    14. #34
      May 2008
      Denmark
      Quote Originally Posted by modularboy View Post
      ...that AJE K-Member , is that specially for a 69-70 Mustang, or is it for a foxbody or SN-95 or something like that?
      Thanks!
      And AJE Racing makes the K-member specifically for 64-66 and 67-70 Mustangs. http://www.ajeracing.com/64-70Mustang.php
    15. #35
      Mosjoen, Norway
      Country Flag: Norway
      Nice, I like it!
      Joakim Vike
      -70 'Cuda
      Member of the Rapid Transit System
    16. #36
      May 2008
      Denmark
      Got the rear wheels back from Vaughns Machine in LA, widened from the standard S197 9.5" to 11". Really nice work and very little weight needed to balance it out. Looks good on there too (ride height not set in these pics).
      Front suspension taking shape:
      Engine mocked up with the shiny stuff:
      Rear spoiler repositioned to where it might actually do some good:
      Turbo showed up. 80mm wheel, framing is T6 and the A/R is 1.32. 44 lbs of forced fun!
      3 surplus emblems, hobby knife & black epoxy - and too much time:
    17. #37
      Chesapeake, VA
      Great thread, I've been watching enthusiasically. I like the relocated rear spoiler. Not only because it "might actually do some good" but because it's a subtle change that makes the car look different, but someone might not realize why.
    18. #38
      Dec 2007
      Bakersfield,CA.
      Did you make your subframe connectors? If so, out of what?
    19. #39
      May 2008
      Denmark
      Jaybee, thats my style too. Stylish and subtle, true to the original.
      The subframe is just cut from 1.5 x 2.5" .120 wall", welded shut with a plate in the ends.
      I finished the main gauge section of the cluster. Took the original lenses out alltogether as I need access to buttons on the gauge faces. Gauges are Speedhut Revolution and they fit PERFECT! They are screwed in but also sealed with a thin bead of clear silicone to keep them from vibrating loose. The aluminum plate shown was drilled after the pics were taken and mounted to the back of the cluster with 5 screws:
    20. #40
      Beaufort , NC
      MAN those gauges are THIN!!! I hate my Autometer Phantoms after seeing this.......
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
