Thread: T-400 modulator
05-28-2008 #1
New to Pro-Touring
- Jun 2007
- Alberta
- 41
T-400 modulator
Been so long since I drove it;has manual valve body so do I still need to hook up vaccume to modulator ?
05-28-2008 #2Yep, or it will never shift out of first gear at part throttle. Get a red stripe modulator so you can adjust the screw inside it to have some control over shift points.
05-28-2008 #3If you have a manual control valve body, which it sounds as though you do, you shouldn't need a vacuum modulator. Most of the manual valve bodies, just plug off the port. Do you know what brand you are running?
05-29-2008 #4
New to Pro-Touring
- Jun 2007
- Alberta
- 41
T-4 mod.
no it was built about 15-20 yrs ago;low first gear etc.cost $2500 bucks then,I didn't think it neededV supply thanks again!
05-29-2008 #5Whoops! My bad. I read right past that "manual valve body" part.
06-06-2008 #6
