Results 1 to 20 of 289
Thread: G-body FE3X Pro-touring project
05-24-2008 #1
- Sep 2004
- Near Dayton, OH
- 547
Have yet to post a full description of my project so thought I would take the time to do it today. Especially since I'm making a little progress. ;)
Car:
1987 Oldsmobile Cutlass Supreme. Originally a 307/TH-2004R/2.56 car that was my first car when I turned 16. During college I had the rear rebuilt with a 3.73 gear and Aubrun limited slip unit. Later I swapped in a mild 455 BBO and then upgraded the TH-2004R to an Art Carr unit. Put a set of 17x8" Hopster wheels with 245/45 front and 255/45 rear and pretty much stopped there.
Here is a pic as it last stood:
The body was needing some major attention so I sent it down to a friends house to be repainted. We ran into a few things along the way and needless to say, ended up pulling the body off the frame and doing a complete overhaul.
I am now in year 5 of this build. Mostly due to a clear plan at the beginning and money but I should have it finished by summer of next year.
Engine:
Same as what was in it, the 455 BBO. But this time its under going a little bit more "racey" build.
1976 455 bored .060" over (468)
Crankshaft: 425 forged crank, offset ground to 4.25" stroke with BBC 2.200" rod journals.
Rods: Manely aluminum 6.990"
Pistons: Arias forged flat tops with 2cc valve reliefs
Compression ratio comes out 11.35:1
Camshaft: Custom ground Comp Cams hydraulic roller (still being spec'd at the moment)
Heads: Edelbrock performer RPM with 2.120" Int/1.710" Exh, chambers and exhaust runners/bowls polished. Intake runners smoothed but no real porting.
Intake: Offenhauser Super-Sonic dominator flange single plane. Modified for EFI
Throttle body: Edelbrock 1600cfm dominator flange
Controller: MSII with fuel and spark control
Exhaust: Kooks 2" primary/3.5" collector headers into 3" exhaust with X-pipe and Spintech Prostreet mufflers dumped before the axle.
Engine picture:
Transmission: Stock T-56 6 speed from a '96 SS (for now) This will probably need upgraded later.
Clutch: Looking at a SPEC stage III
Rearend: Ford 9" with Detroit Tru-Trac limited slip. Still undecided on gears.
Suspension.
Front:
SC&C StageII kit with Pro-lite lightweight adjustable upper control arms. HOWE racing tall upper and lower ball joints. Stock lower control arms with Global West Del-A-Lum bushings. Moog 5662 IROC springs with one full coil cut. F-body 36MM sway bar. Rebuilt F-41 quick ratio steering box. Bilstein shocks. C5 Corvette calipers with LS1 12" rotors
Rear: Edelbrock double adjustable upper control arms with spherical bushings. Currie-trac lower control arms with spherical bushings/poly. Moog CC635 F-body cargo coil springs. Bilstein shocks. Sway bar, still waiting on the SC&C pro-touring bar. LS1 disc brakes with 12" rotors.
Wheels/Tires
Front: 17x9.5" American Racing TTII Classics with 245/45ZR17 tires
(These will probably get changed out once the car is on the road)
Rear: 17x11" American Racing TTII Classics with 315/35ZR17 tires
Wheel pictures:
Interior:
Pretty much stock with a few upgrades.
Classic Instruments All American Nickle series gauges.
Stock dash dyed black.
NOS burlwood dash inserts.
Hot Rod Air A/C system
Procar Ralley 1000 front seats with recovered stock rear bench seat.
Sound deadening EVERYWHERE!
A few interior pics:
I hope to have a dyno video of the engine up by the end of the summer. Still need to assemble it. Hoping for something the neighborhood of 550HP and 600ft/lbs but I think my heads are going to be my limiting factor on this. :(
Thanks for looking!Andrew
1987 Olds Cutlass Supreme FE3X Clone
EFI455/T56/9" w/ 4.30 gears
__________________________________________________ __
05-25-2008 #2I've seen this car before, but this is the first for some detail shots. Excellent work. The car look absolutely MENACING with those 315s out back. Thats the combo I really want to run, but I can't afford fat tires of that caliber. (Other than Sumi's, which I hear are garbage. So, good luck with them.)
Keep us updated...seems to be one sweet project.
05-25-2008 #3
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
I love this project - keep up the great work!
05-25-2008 #4
- Sep 2004
- Near Dayton, OH
- 547
Thanks guys.
Regarding the Sumitomo tires, yes they are pretty much junk. I bought a set for my daily driver Intrigue just to see how they would be and while they made a huge difference in how it handled, I was replacing them after 15,000 miles because they were worn out!
But, at $110 each for the 315's they'll serve well as mock-up tires and the first sacrificial tires on the street. I can guarantee that whatever tire is back there once I get this car going again isn't long for this world anyway. So it might as well be a cheap set. ;)
In a few weeks I'm pulling the body back off the frame to run my fuel and brake lines, plus clean the underbody a little better and lay down some more sprayable sound deadening. My goal, (I don't know if its going to happen yet or not) is to have the car completely driveable by October/November of this year and then over the winter have my friend do the rest of the body work and paint it.
Thanks guys.Andrew
05-25-2008 #5looking good man though I'm more a fan of the w-30 hoods
GTO Project https://www.pro-touring.com/showthre...-The-Great-One
Colorado Project https://www.pro-touring.com/showthre...cab-CodeRedZQ8
Check Out My YouTube Channel http://www.youtube.com/c/geedsgarage
05-25-2008 #6
- Sep 2004
- Near Dayton, OH
- 547
You mean like this one:
There are two problems with the W-25 hood though. 1) It offers no hood clearance at all and 2) the hood scoop angles don't match the front of a G-body and it looks a little out of place, IMO.
So I probably won't be using this hood I have and going a different direction. Not using the cowl hood in the picture above either.
My latest idea is something like this:
http://i169.photobucket.com/albums/u...aps/BB0455.jpg
Or without the "stinger"
http://i169.photobucket.com/albums/u...ps/BB04554.jpg
Or I may make my own stinger that matches the body lines a little better.
But the body work is still a ways off.
Thanks,Andrew
05-25-2008 #7Looking good
JEFF SHORTT
-IDEAL STEEL
05-25-2008 #8
- Aug 2004
- Dunwoody, GA
- 4,983
