Thread: Pilot bearing problem???
05-15-2008 #1
- Jan 2005
- Dallas TX
- 1,633
Need a quick answer if anyone has one.
I bought the Supercars unlimited adapter bearing to use an Olds auto crank with a std transmissions. I was measuring how deep I need to drill my crank to clear the input shaft. I had the bearing slid down the input ishaft and noticed there was visible run out. I pulled the bearing off and measured and there is .006 difference in the debth on how deep the center bearing is pressed from one side to the other . Basicly it must be pressed together slightly crooked
Am I being too anal or will this be a potential problem?
