Results 1 to 13 of 13
Thread: Newbie with Spring question.
05-08-2008 #1
I have a '71 Chevelle Convert with 18" front and 20" rear, and I want to lower the car 1.5" front and 2.5" rear. It has a 454 in it. I called coilsprings.com and they told me they can make the springs as long as I have the specs..... Hence, my quesion. What size, rate, load ect... do I need to give them, so they can make me the proper springs for that amount of drop? If anyone has a better idea for either cost or availability, I'm all ears.
Jeff
05-13-2008 #2Bump. Really, nobody out there has any info that may help me?
05-13-2008 #3
Starting The Transformation
- Dec 2004
- Greeley, Colorado
- 485
you might look in to purchasing coils that are pre-fabbed for that type of application. I'd check out Hotchkis myself.
Jason Mounce
1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
05-13-2008 #4Hotchkis only has one kit and I believe it's only 1" front & rear. Eibach is the same, but their's is a 1.3" all around for SB only. Thanks for the reply though.
05-13-2008 #5
- Jun 2007
- Kirkland, WA
- 33
What is your current spring rate and free lenght?
05-13-2008 #6They are stock springs. From there, I don't know the specs.
Originally Posted by Balance_Point
05-13-2008 #7
- Dec 2004
- Greeley, Colorado
- 485
Sounds like a good candidate for a shorter spring with a hidden adjuster.
Originally Posted by resto-mod
I'm not sure the diameter and free length of your stock springs, but you can go with a shorter spring from AFCO or Speedway Motors along with hidden adjusters to dial in your ride height accordingly.Jason Mounce
05-13-2008 #8Speedway only has the Eibach kit and AFCO seems as though they are going to want the complete dimensions of the springs I want made. Is there anyone that knows who to contact that I can order from, just by telling them I want to drop the car 1.5" front and 2.5" rear? Or.... "plan B" would be to have the specs to tell someone such as AFCO I need ________ (fill in the blank). I'm OK with the spacer idea, but I'd rather get the right product, as opposed to ordering a band-aid to cover up an error.
05-13-2008 #9
- Dec 2004
- Greeley, Colorado
- 485
Speedway Motors also sells individual coil springs. about $50.00 per.
For example. The F-bopdy cars use a 5" diameter spring. I'll be running a 5x9.5 spring along with the hidden adjuster.
In all honesty though you're going to need to take a spring out and get the specs to figure out what you are wanting.
You're talking about weight loading calculations as well as free length. Or you could simply remove your factory springs and start cutting them. Try a 1/4 coil at a time.Jason Mounce
05-13-2008 #10
- Jun 2007
- Kirkland, WA
- 33
Measure the diameter of the spring wire, how many coils, and how tall the spring is (free length). Anyone who makes springs should be able to figure out your desired drop from there.
05-13-2008 #11Is there a proper name for the "hidden adjustor"? Does anyone have a link or info on where to purchase them? It sounds like I may be best off getting the shortest spring I can use w/out bottoming out, then use the "adjustor" to lift it to the desired ride height. Is this a "normal" way to do this?
05-13-2008 #12
- Dec 2004
- Greeley, Colorado
- 485
springs
http://www.speedwaymotors.com/p/163,...2andquot;.html
adjuster
http://www.speedwaymotors.com/p/3389...-Extended.html
It looks like the chevelle through 73 uses the same diameter spring as the f-bodies. Go with the 9.5" length spring with the adjuster.
A spring rate around 600lbs is probably okay for you, that's what most of the aftermarket spring rates come in at.Jason Mounce
05-14-2008 #13JLM, Thanks for the info! Now I'm cooking. I'll post pics when I'm done.
