    Results 1 to 3 of 3
    Thread: G-bar exhaust
      Winchester, VA
      G-bar exhaust
      Does anyone know if you can run a full 3" exhaust over the axle with a g-bar installed in a 2nd gen Camaro?
      I have two different routes to go depending on this:
      1. G-bar rear with QA-1's
      OR
      2. Comp/Racing leaf spring set-up from Pro-Touring F-body with PRO Shocks, possibly Herb Adams mod?
      These will be used regardless:
      -285/40-17's rear
      -3" exhaust (probably Magnaflow 3" w/x-pipe - have 500+ hp 406)
      -8.5" 10 bolt (3.23's and Powertrax posi)
      -TKO 600 (.82 5th)
      -Pro-Touring F-body (GEN II Racing) front springs and PRO-Shocks and sway bar
      -245/45 or 275/40-17's front
      Thanks,
      Wayne Smith
      '70 Camaro - 406 - Street/Strip being converted to Pro-Touring (best 1/4 run - 11.05 @ 121, 1.50 60' - NA)
      '47 Chevy truck - 250 L6 / 5 spd - Resto Rod/Work Truck in the works
      Aug 2003
      You can but a nothced corner tank similar to what has to be used on a Quadra Link helps a bunch
      Winchester, VA
      Thanks Frank. What route would you go? The car will be mainly street with occasional track time at my local roadcourse track - just some club and timing runs.
      Wayne Smith
