      Another back spacre question
      Guy's will a 10in wide wheel with 4in backspacing fit on a 69 camaro that has been minitubbed with a stock width axle,oh with a 295/50/15in tire.THANKS!
      May 2002
      Northern California
      nope, your gonna want to go in more than that. 6" BS would be a better number.
      To run that rim size properly you will need to narrow the rear end a bit. You looking for a nice deep lip rim?
      What is your location.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2003
      Houston, TX
      MrQuick is correct, those are going the wrong direction on backspacing. We generally use 5.5" backspacing on a 10" wheel for the 69. If you go with less backspacing, it moves the wheel outwards, so it will hit the fender lip.
      For a stock width axle, you only gain the ability to run a wider wheel than 10", but these inches are added to the backside of the wheel, not the front.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Thanks for the reply's, I kind of figured this wouldn't work but thought I would ask,located in south alabama.THANKS AGAIN!
