Results 1 to 20 of 22
Thread: combo help!
04-29-2008 #1
combo help!
I just bought a '65 Malibu and i could really use some help from the gurus here about picking some parts for my new motor. so heres what ive got so far:
Ive got a '70 2boolt 400sbc, bored .030 over
6.0 Scat forged i-beams
Ross 95765 pistons 12.1:1 w/ 58cc, 11.3:1 w/64cc , 10:1 w/76cc
-4cc dome
Scat cast crank
total cid is 406
weiand x-cellerator intake
lunati solid lifter bracket master II cam. specs are 256/270 @.050 and 500/515 @.050
full length headers
1.5 roller rockers
i know i still need to get the main studs
it will have a 750 holley double pumper
edelbrock fuel pump
high flow aluminum water pump
now i just need to get some heads that will allow me to spin this puppy to 6300-6500rpm. keep in mind that im on a little bit of a budget. any help would be very appreciated.
04-29-2008 #2Whats your plans for the car? Do you want a maintance free combo? Do you want a pump gas motor?
My off the top of my head suggestions, go around 10.1 - 10.5 comp. You don't need studs just good bolts.Lose the solid cam, but a Hyd roller in it, intake is ok not the best I would go with a Performer rpm. I prefer Brodix Heads, a IK200 or Track 1 head will be good.Thall shall fear no amount of boost, For thy bottle is with me.......
04-29-2008 #3the plan for the car is to have a fairly nasty street car that gets driven maybe 2-3 times a week. and a trip to the strip once a month or so. as far as a hassle or maintenece free combo, adjusting valve lash and what not really doesnt bother me at all. even if i have to mess with it every 2 weeks thats ok. pump gas? yes thats a must. the hyd roller conversion puts me out of my budget and ive already bought the intake and cam/lifters so i kinda have to stay with that stuff.
04-29-2008 #4I just saw a combo similar to this make huge power using Edelbrock E-tec heads.
From my buddy Marv
here is no real high tech combination to this. A Hughes street TH350, a Jeggs 2800 convertor, 4.10 gears, a Lunati streetmaster hydraulic cam (#00012) 10.2:1 ,, and Dana's launching from 1500rpm and footbraking, shifting at 6000 and going through the traps at 6300ish (11.58@115) in a 3300-3400 pound car. I tell ya, them little 9" Hoosiers are sure doing as good of a job as those little 170 E-tech's1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
04-29-2008 #5The cam specs Marv used:
Intake Duration at 050 inch Lift: 246
Exhaust Duration at 050 inch Lift: 246
Duration at 050 inch Lift: 246 int./246 exh.
Advertised Intake Duration: 300
Advertised Exhaust Duration: 300
Advertised Duration: 300 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.515 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.515 in.
Valve Lift with Factory Rocker Arm Ratio: 0.515 int./0.515 exh. lift
Lobe Separation (degrees): 1081971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
04-29-2008 #6
Banned
- Aug 2003
- Orlando, FL
- 8,745
I would put some 215CC heads on it, and ditch that cam for a another (a solid roller would be awesome) with more lift (580 to 600 range would be nice) and a tick more duration on the intake side less on the exhaust side. Something in the 255 / 260 range on 110 would be good. If you want it really nasty, tighten it up to 108 or 106LC, but it will get a bit more peaky!
Your going to need more carb, maybe a 830 Annular
04-30-2008 #7the heads in the 200-215 range is what im looking at right now. as for the solid roller...it sounds like a geat idea, but that moves my powerband into a much less usable area for me as i want to be able to drive this thing with some degree of comfort on the street. me and a few of the guys like to do a little cruise to South Beach and the traffic does tend to get a little thick when we go. the motor has to be trouble free in stand still traffic on a 90degree day and on a hundred mile drive (about the miles it is from my house to Moroso MotorSports Park). thanks about as far as i plan to drive it on one trip. does that sound like a doable thing?
04-30-2008 #8a roller cam is no different than any other cam, get it ground where it works for, it just allows alot more aggresiveness in the profile and wont wear out like a flat tappet cam
05-01-2008 #9^true. but, how i understood it, if i were going to drive this thing in traffic and and cruising around town the solid roller would be too much? wrong information? my specialty is interiors, so when it comes to engine building and setting up parts to work together, i could use all the help i can get. I had someone tell me that my intake was wimpy. does anyone else think that is is not enough to keep up with my motor? probably going to go with the Sportsman II heads from World Products 200cc/72cc chambers.
05-01-2008 #10
