Thread: Stainless Steel weld
04-26-2008 #1
New to Pro-Touring
- Sep 2006
- 37
How do you produce this kinds of welds.I have 304SS tubing.We want this look on our exhaust tubing.I know its tig welded, what filler rod is used.I had some exhaust welded and its not even close to the way this looks.
04-26-2008 #2Whoever made that weld didn't start welding yesterday. He (she) probably has a few years behind him. You could use 304 or 308 filler. That being an inside corner weld helps too as that is an easier weld to make than say an outside corner. Easy on the heat and I would think no bigger than 1/16" filler. A pulse tig would be an advantage to some also.
04-27-2008 #3
Starting The Transformation
- Feb 2008
- Denver NC
- 288
