    Results 1 to 9 of 9
      Good Gas Cap for 67-68 Camaro?
      Anybody got a suggestion on a good gas cap for a 67-68 Camaro? While I love the original GM SS gas cap that came on my car looks wise, I hate it otherwise. It leaks like crazy under moderate plus accelleration and it's a general pain in the rear when getting gas. It's got a large gauge wire that holds it on to keep someone from stealing it. Great idea in concept - PITA otherwise.
      I really wanted to get one of Larry's billet caps, but I've got to go ahead and do something. I'm tired of smelling gas every time I want to play a little bit.
      Any suggestions are very much appreciated.
      GeoffP
      68 Camaro - LS1/T-56
      USA
      I put a non-vented cap on my '69 Camaro.
      Of course a '68 cap is exposed and the '69 cap is under the tag.
      Now it doesn't leak.
      BUT ! , it builds up pressure and I keep thinking this will cause a problem.
      Like , blowing out some seals in the fuel system or something.
      I even had a bad fuel leak last winter after the car sat a while because the fuel system built up pressure and it started to seap out of the fuel line up front. ( I had the carb disconnected at the time )
      I smelled fuel and was like, " What the hell ? ! "
      Anyway, I have to release the pressure off the fuel tank every time I stop. Just to be safe.
      Jeff Tate
      U.S.A.
      I had a car that did that years ago. It would always hiss when I opened the cap to put gas in. I just started leaving it slightly loose to keep it from building up pressure.
      I'm going to the Summit store today - plan on making a list of needs on the way over. Maybe I'll get lucky and find something that will work and looks nice.
      GeoffP
      Hmm - I thought for sure someone would have a good suggestion on this.
      GeoffP
      Jan 2000
      Thousand Oaks California
      Well, I will get back to my filler caps as soon as my Camaro leaves for Prodigy Customs in about a week.
      Larry Callahan
      Thanks for the reply Larry. I will keep yours in mind if I haven't already bought something else.
      GeoffP
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by Larry Callahan
      Well, I will get back to my filler caps as soon as...
      Yeah... right. Where have I heard that before ??
      ...After SEMA.
      ...After I get married.
      ...After things at work slow down.
      ...After SEMA (the following year).
      Jan 2000
      Larry Callahan
      Jan 2009
      Massachusetts
      Quote Originally Posted by JEFFTATE View Post
      One time I "lost" the cap to my '69 so I bought a new cap. Once the hot weather came in, my car would always have a hard time starting if it sat for a while, but then if it sat a bit longer it would be fine. finally realized that I was getting vapor lock. It took me a while to put one and one together (I have a bad memory), but I finally realized that I replaced a vented cap with a non-vented one. Once I fixed that... no more hard starting. So I never mind smelling a slight bit of fuel anymore
