Results 1 to 20 of 29
Thread: Alston Vari Shock Help
04-16-2008 #1
While changing the springs on ALston coil overs that I installed last summer I found one of the shocks was leaking and the top cap was loose. Alston's website says the shocks are rebuildable but I could not find any information on kits.
Does anyone have any information in rebuilding these shocks? Rebound dampiong seems to be fine but there is no compression at all. Is it too much to ask that I may only need to put the specified fluid back in the shock? I've only got about 800 miles on them.
1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
04-18-2008 #2pm sent
04-20-2008 #3If anyone has info on this please forward it to me as well. One of my varishocks is leaking although I haven't noticed a change in damping yet.
04-20-2008 #4Fist off thanks for the great email Amber (firbird96ta) great information and I will be getting in touch with you soon.
Jeremy, Amber sent me a very detailed email on rebuilding the the Alston shocks. If she does not mind I can post the information here. In the meantime I suggest dropping her a PM and I am sure she would be more than willing to help you out as well.
have you disassembled the shocks yet? Do you know where the leak is coming from? In my case it was from the top gland nut and caused by improper assembly from a disgruntled (now ex) employee. Once I got on the phone and did some checking I found that Alston knew of the problem and was centered around shocks built early last year. They did offer to send a shipping tag for me to return them for rebuild but I do not have the time to deal with shipping the shocks back, having them repaired and shipped back to me. It took about 30 minutes for me to rebuild each shock. but again there was no damage to my shocks other then the gland nut was not properly tightened down.
04-21-2008 #5No problemo, John. Glad you got them back together okay. Nice Monte, BTW; I'm hopelessly addicted to my f-bodies but if I were forced to drive something else, an SS is definitely what I'd have
I don't get to check these forums much so if anyone else has any issues or questions, feel free to email me. It would probably be easier to forward the email rather than post it here; it's rather long for a post
(besides, I don't know for sure if CAC wants that info posted per se, but I'm perfectly willing to share it on a one-on-one basis). Or if anyone will be at the Year One Experience next month, you can look me up at the air ride autocross and we'll chat.
04-21-2008 #6I haven't pulled the leaking one yet, but the entire shock body was coated in oil when I looked things over to confirm it was the shock leaking.
I checked my records and I installed the shocks last April. I'll give Amber an email for sure.
04-21-2008 #7Last April puts you right in the same time frame as me and probably the same production problems. I'll PM you a copy of what Amber sent.
Thanks for the help Amber
04-21-2008 #8
- Dec 2006
- 12
I found both my fronts were leaking from the same thing, loose caps. No damage so I took them apart and refilled them myself. I would like to hear what you used for fluid. I had enough fluid in both shocks left to calculate the viscosity of the original and used fork oil that was almost identical. Please post it here for everyone else later who may need the info. If not, please send me a copy if it is not too much trouble.
04-22-2008 #9buddyholly, not sure what oil CAC's guy used...in our units, we're running Tellus T22 which also may change very soon.
<---saw this smiley and just had to use it
04-22-2008 #10
- Dec 2006
- 12
Thats interesting. I calculated the Varishock to be right at 22cts @40C so that is very close. Locally the closest I could find was around 26cts@40 so it moved my shock stiffness up the scale a bit but still works fine. Just for those who are interested in shock oil
http://www.pvdwiki.com/index.php?title=Suspension_Fluid
04-22-2008 #11
